Activity › Forums › Sony Cameras › Sony XDCAM Transfer and Snow Leopard
Tony Gordon replied 16 years, 1 month ago 13 Members · 47 Replies
Craig Seeman
September 17, 2009 at 3:09 pmSnow Leopard. You need to download the new SxS driver.
Search forum. I posted the link to the Canadian site. I’m still not sure if US site has it. -
Bill Parker
September 17, 2009 at 3:32 pmI installed the driver from here:
https://www.sony.ca/promedia/drivers.htm
It didn’t make any difference. I still don’t see the thumbnails in XDCAM Transfer and the plug-in in FCP for Log & Transfer doesn’t recognize my cards.
Not sure what I’m doing wrong.
Thanks.
Steve Reiman
September 19, 2009 at 11:23 amI installed the NEW sxs driver on my Macbook Pro. Also i installed the XDCAM Transfer Package 2.9.0. As i did, i got the same problem with the thumbnails like described from others…
My fix for that:
I used PACIFIST to ectract only the XDCAM Transfer.app from the old 2.5.1 package & replaced the new 2.9.0 with the version 2.5.1
All works perfect & stable.
Craig Seeman
September 19, 2009 at 5:11 pmCurious what about the XDCAM Transfer install causes the issue. If it’s this simple Sony should have the courtesy of offering the workaround on their site. BTW current version of XDCAM Transfer is 2.10. 2.5.1 has bugs that you may run into. I think 2.7 was good and additional version has just a few bug fixes but mostly additional features, some of which not critical to EX use.
David Dewhurst
September 23, 2009 at 3:36 amChris,
Can you give a more detailed explanation of how you used Pacifist to solve the Snow Leopard/XDCAM Transfer problem. -
Paul Vlachos
September 25, 2009 at 2:55 amTony,
I’ll buy you a coffee if you ever make it to New York.
After weeks of idiocy and failure, that simple reversion worked. At least, on one of the big Mac Pro hogs. About to do another machine now.
THANK YOU!
Paul
Paul Vlachos
September 25, 2009 at 3:01 amTony, it works with one caveat that I found. The Sony XDCAM Transfer folder to trash in Application Support is not in /library/application support, but in users/username/library/application support.
Steve Reiman
September 30, 2009 at 3:52 amjust open the package with PACIFIST… browse to the application inside the package and extract the app to your desktop without installing the whole package… (so u cannot overwrite the NEWER VERSION COMPONENTS)
…this is working for me…
1x PMW-EX1, 2x HC-1
https://xteve.dynips.net -
Thijn Teeuwissen
November 3, 2009 at 3:36 pmHi Tony,
I have the same thumbnail problems, so I followed your advice but xdcam transfer 2.5 doesn’t open at all.
/Users/thijn/Desktop/Schermafbeelding 2009-11-03 om 16.16.21.pngwhat can I do?
I work with Snow Leopard and Final Cut Pro 6.0.6
Log and Transfer works fine but I need Xdcam Transfer also because I also work with the Sony PDW530p broadcast camera.Regards,
Thijn Teeuwissen
ENG cameraman, The Netherlands -
Craig Seeman
November 3, 2009 at 4:09 pmUltimately I think we’ll have to wait for XDCAM Transfer 2.11.
I suspect we’ll see that in December when the Sony EX1R starts shipping.
Sony Clip Browser 2.6 is already available on the Sony European site although not in USA or Canada.
