Activity Forums Sony Cameras SONY XDCAM EX1 FREE RUN problems
  • SONY XDCAM EX1 FREE RUN problems
    Posted by Nikola Bizic on February 8, 2008 at 4:24 am
    I am having problems with EX1 free run mode.
    I set free run mode with IR remote to 2 EX1 in the same time and only after 2 min TC was different on both camera. Than I took another and do it same thing again with 3 EX1.
    TC was different in every camera only after 2 min. Difference was about 3 frames.
    After 2-3 hours of running difference was about 2 sec.
    Is there anybody else having the same problem?
    2 x SONY PMW EX1
    MacPro XEON
    Steve Wargo replied 18 years, 6 months ago 4 Members · 6 Replies
  • Steve Wargo
    February 8, 2008 at 6:57 am
    All cameras have this problem. The higher tech cameras have TC in and TC out. You start with a lead camera and set the TC and then run a cable to Cam 2 and out of that the Cam 3 Etc.
    On the larger cameras, you can use a Deneke Time code box which you set with one camera and then use one on all of the other cameras. they have a crystal in them that keeps accurate time.
    TC in and out is one thing that we were all hoping for but that’s not the case. What we will do is use a Deneke TC slate and shoot the slate occasionally or each time the cameras restart. Then, on each clip, you align to the TC displayed on the slate instead of the TC recorded on the tape.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1.
  • Nikola Bizic
    February 8, 2008 at 5:11 pm
    for answering my question.
    You solved my dilemma.
    We use slate a lot, but on ENG shooting some times there is no time for slate.
    I tried to make syncing two shoots faster (with using free run on ex1) but its clear that it can not be done in that way with EX1.
    Thank you again!
    Nikola Bizic
    Belgrade, Serbia
    2 x SONY PMW EX1
    MacPro XEON
  • Chris Babbitt
    February 8, 2008 at 5:52 pm
    Just take along a camera flash & flash it for a sync point.
  • Nikola Bizic
    February 8, 2008 at 11:39 pm
    Nice flash idea.
    2 x SONY PMW EX1
    MacPro XEON
  • Michael Palmer
    February 9, 2008 at 4:36 am
    And then you can experience the rolling shutter first hand.
    Good Luck
    Michael Palmer
  • Steve Wargo
    February 9, 2008 at 5:48 am
    [Michael Palmer] “experience the rolling shutter”
    Kill two birds with one flash.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    2-Sony EX-1.
