Activity Forums Apple Final Cut Pro Legacy Sony XDCam EX1 1080i print to tape?
  • Sony XDCam EX1 1080i print to tape?
    Posted by Gary Ellison on July 21, 2010 at 3:03 pm
    Hey all,
    I’ve got footage taken from the ex1 camera shot at 1080i pal, and would like to print to tape on my Sony DV/HDV deck. I don’t mind it being down converted. When I attempt this the video starts printing to tape but the sound comes through all distorted and inaudible, and the audio bars on the deck have written above them “NS”.
    Can anyone help with this problem? Would much appreciate it!
    Cheers
    Jeremy Garchow replied 16 years, 1 month ago 2 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    July 21, 2010 at 3:30 pm
    Are you trying to do this via firewire? You should have a capture card for this.
  • Gary Ellison
    July 21, 2010 at 3:36 pm
    Yes sorry it’s via firewire.
  • Jeremy Garchow
    July 21, 2010 at 3:38 pm
    Then I would export the movie and use Compressor to make a DV version. Then lay the dv version off via firewire.
  • Gary Ellison
    July 21, 2010 at 3:41 pm
    I tried that and the sound still came out wrecked. I even tried making it dual mono in the fcp sequence instead of stereo to see if that worked, but nada.
  • Jeremy Garchow
    July 21, 2010 at 3:43 pm
    [Gary Ellison] “I tried that and the sound still came out wrecked.”
    Is your deck in HDV mode instead of DV?
  • Gary Ellison
    July 21, 2010 at 3:49 pm
    It was on Auto. When on DV the video comes through but the sound is ruined. When I set it to HDV FCP could not find the deck. Anyway of fixing this?
  • Jeremy Garchow
    July 21, 2010 at 4:00 pm
    Are you using the DV easy setups in FCP?
    Is your sound set to 48k? This is all pretty basic stuff.
  • Gary Ellison
    July 21, 2010 at 5:45 pm
    I’m talking about the settings on the Sony Deck, my FCP settings are fine, and cheers for the snide tone I guess.
  • Jeremy Garchow
    July 21, 2010 at 7:02 pm
    NS I would think stands for no signal?
    Why isn’t it getting there? Must be because your deck isn’t setup properly. 1394 should be in DV or DVCam if possible?
