Activity Forums Sony Cameras Sony XD Cam / dropped audio at end of files
  • Sony XD Cam / dropped audio at end of files
    Posted by Dunwoody Lampton on November 26, 2023 at 2:38 pm
    Sony PXW-X70, PNY 32gb, AVCHD MPEG-2
    Recorded a musical production featuring two parts with each approximately 75 minutes long.
    As usual, files were about 2gb in size – with the camera creating a new file every 11 minutes.
    No break in video frames, but there was no audio for the final second of each file.
    No idea why, or if the audio is recoverable.
    Hector Vera replied 2 years, 9 months ago 2 Members · 1 Reply
  • Hector Vera
    December 1, 2023 at 1:03 am
    That is weird, sometimes this issue can happen depending on the SD Card you use on your Sony CAM, I know some cheap SD Cards tends to cut out audio in parts of the clips for me but if you used the SD Card for a long while and just now giving this issue, could be a sign of the SD Card wearing out a bit. Good to keep testing it to see if the problem continues or not. Best of luck!
