Activity › Forums › Apple Final Cut Pro Legacy › Sony Vs Final Cut Pro Round 1
Posted by Simon Gooden on June 21, 2010 at 11:06 pmHELP !
Stuck…Trying to import media from sony memoery unit into fcp 7..heres the deal.. Currently on mac 10.5.6 mac os x , fcp 7..
Copied HDV media ( m2t ) into cature scratch disk.. tried using log and capture and nothing happens. No, ‘ New folder in top left corner, and cant drag and drop media either. Do i need to change capture presets or other settings, if so what..?) This is not quite as simple as Sony makes out…
Thanks in advance..
Rafael Amador replied 16 years, 3 months ago 3 Members · 7 Replies -
Shane Ross
June 21, 2010 at 11:21 pmFor tapeless import, you use LOG AND TRANSFER. Log and CAPTURE is for tape media only.
If that doesn’t work, try CLIPWRAP, or MPEG STREAMCLIP.
Shane
Read my blog, Little Frog in High Def -
Simon Gooden
June 21, 2010 at 11:27 pmsorry , thats what I meant. I did use Log and Transfer, but files dont show up and I cant import them.. im probably being stupid and tired, well im defnitely tired..!!
have viewed clips in streamclip but need to edit..
thx.
Shane Ross
June 21, 2010 at 11:33 pmIF L&T won’t work, that means that the full card structure isn’t present. If you can view them in MPEG STREAMCLIP, then export from there as an editable codec…like ProRes. It isn’t mainly a viewer, it is conversion software.
Tutorial:
https://lfhd.net/2009/06/26/mpeg-streamclip-tutorial/
Shane
Simon Gooden
June 21, 2010 at 11:37 pmCard structure… ? how do i fix this..?
wanted to avoid having to convert all the media back to a fcp friendly format..have hundreds of clips…arrggh.. thought this was going to be easy…
Shane Ross
June 22, 2010 at 12:36 am[simon gooden] “Card structure… ? how do i fix this..? “
The entire file structure on the card that you pull from the camera. When you backup the card to a drive, you need to make a new folder, name that folder something unique (this is your REEL number), and then drag EVERYTHING on that card, in the structure it appears on the card, into that folder. If you don’t, and you erase the card, then there is no way to recover the full structure, as there are small subfolders that contain information that FCP needs to import the footage.
If you lack that, then look at ClipWrap or MPEG STREAMCLIP to convert the footage.
[simon gooden] “wanted to avoid having to convert all the media back to a fcp friendly format.”
Wait…what? You want to work with the footage in FCP, but don’t want to convert it to a codec FCP works with? I don’t get what you mean.
[simon gooden] “have hundreds of clips…arrggh.. thought this was going to be easy… “
It IS easy, if you do things right. Copy the full structure, use Log and Transfer to view the footage, and import what you want, name the clips as you do…done. Without that, you have to use MPEG STREAMCLIP to view the footage, and convert.
Things are easy when you do things right.
Shane
Simon Gooden
June 22, 2010 at 12:47 amI couldnt agree more…
I did ‘ select all ‘ from the card but i guess I could have missed smaller sub folders..i will clearly have to make sure next time. Lucky i backed up to tape..
Yes things are much easier when you do them right…
Thanks for your help..
s..
Rafael Amador
June 22, 2010 at 9:08 am[simon gooden] “e. Lucky i backed up to tape.. “
Hi Simon,
I do not understand your workflow for HDV tapes.
rafael
