Activity Forums VEGAS Pro Sony Vegs 12 open COPY in Audio Editor Keyboard Shortcut anyone?
  • Sony Vegs 12 open COPY in Audio Editor Keyboard Shortcut anyone?
    Posted by Michael Wenz on November 19, 2012 at 7:02 pm
    Hello I am using the Avid MC Control and I have Vegas using Mackie control and its really nice, however I would like to be able to assign a keyboard shortcut to Open Copy in External Audio Editor instead of CTRL+E open in audio editor? Any ideas guys?
    Thank you!
    Michael
    Michael Wenz replied 13 years, 9 months ago 3 Members · 5 Replies
  • Aleksey Tarasov
    November 20, 2012 at 5:08 am
    Options > Customize Keyboard
    Enter “OpenCopy” in Show commands containing text box, then select the command and assign the desired shortcut
    Vegasaur – automation plugins and tools for Sony Vegas Pro
  • Michael Wenz
    November 20, 2012 at 5:25 am
    Fantastic!
  • Michael Wenz
    November 20, 2012 at 9:15 pm
    I found that and I have entered numerous unused key commands and it looks like it should work but it is not opening wavelab. I do have Wavelab linked so if I right click it it does in fact work but key command is a no go…I will keep messing! Thank you!
  • Mark Barton
    November 21, 2012 at 6:09 am
    Make sure when you customize the keyboard you select Global rather than the Explorer tab in the dialog when you assign the short-cut. It defaulted to Explorer for me and it did not work from the timeline, but when I assigned the short-cut to Global OpenCopy then it worked for me.
  • Michael Wenz
    November 21, 2012 at 6:30 am
    Well areent you the coolest guy EVER! That did it!!!!!!!!!!!!!THANK YOU THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!
