Activity Forums VEGAS Pro Sony Vegas_Number of audio busses
  • Sony Vegas_Number of audio busses
    Posted by Levan Katsadze on June 13, 2011 at 12:18 pm
    So, please, tell what would I write into “Number of stereo busses” in audio properties. 26? or 0? 10? 20? please, help me. In which situation is better 0, or 26 or 10 or……..
    please.
    thank you
    John Rofrano replied 15 years, 2 months ago 3 Members · 2 Replies
  • Scott Francis
    June 13, 2011 at 1:21 pm
    Depends on your project, you can add more as needed as you go along as well. I start with 0 and add as needed..
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • John Rofrano
    June 13, 2011 at 1:49 pm
    [Levan Katsadze] “In which situation is better 0, or 26 or 10 or……..”
    There is no “better”. As Scott said, you can just add them as needed. What you asked is like asking “How many video tracks are better?”. See, it depends on what you are doing.
    The reason you can specify how many audio buses in the project template is for situations were you always use the same number of buses. This eliminates having to add them later. For example, if you are mixing for broadcast and the levels of your dialog, music, and sound fx, need to be managed separately, you might default to adding 3 buses to each project for that purpose.
    If you don’t know how many audio buses you need… then the correct number is: 0 (zero)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
