Activity Forums VEGAS Pro Sony vegas won’t render vertical video
  • Sony vegas won’t render vertical video
    Posted by Keshet Kesh on July 3, 2013 at 9:17 am
    I asked this in another forum but i think maybe this is the better place for the post:
    I am editing some footage that was shot with an android smart phone. as it often happens, some of the footage was shot on a wide screen (phone being held on its side) some was shot vertically (phone held normally). while in editing everything seemed to go fine (expect for some reason i can only see the vertical videos on preview mode not on best), but when it comes to rendering – nothing works! I’ve tried every render option i could think of and always same result – the video that is being render features all the widescreen videos and all the audio but the whenever there is a vertical footage i just get black screen (can still hear the video’s audio though).
    Can someone please advise on how to solve this problem?
    Thank you very much!
    Keshet
    Davide Hu replied 5 years, 7 months ago 4 Members · 4 Replies
  • Marck-antoine Simoneau
    October 13, 2014 at 4:30 pm
    Hi Keshet,
    I found by myself this rendering setting that can render video vertically.
    Go to File -> Render As
    Then, open MainConcept AVC/AAC (*.mp4;*.avc) and select Internet HD 1080p
    Scroll down and click on Customize Template…
    In the Frame size: select (Custom frame size) and write your Width: 1080 and Height: 1920 or any values you need.
    Now it should work, at least it did for me, I’m using Sony Vegas Pro 13.0
  • Keshet Kesh
    October 14, 2014 at 12:25 am
    cheers mark.
    I’ll attempt that in the future if i’ll have that issue again!
  • Krirkwit Teeravajanadet
    June 6, 2015 at 11:35 am
    finally found the solution!!
    I met this problem also, and found that Sony Vegas just didnt render vertical video. So, you just rotate the video 90 degree and save it again to be new file. I suppose to use the program Freemake Video. That’s it!!
  • Davide Hu
    January 18, 2021 at 11:28 pm
    You damn saved me! Thank you soo much, i had a problem that don’t let me render as 1080×1920, somehow you helped me! 2 hours searching XD
