Sony vegas won’t open
Posted by Robert William on June 16, 2008 at 8:41 pmHello,i’m having this problem since past 1 week.When ever i click on sony vegas it stops “audio engine”I’ve tried suggestions given in this link and in this link
Thanks..
Robert William replied 18 years, 2 months ago 2 Members · 6 Replies -
Steve Rhoden
June 16, 2008 at 11:28 pmDisable your internet connection before opening vegas (dont be online when opening)..try and see if this helps?.
Steve Rhoden
TNX EFFECTS STUDIOS. -
Steve Rhoden
June 19, 2008 at 9:03 amWell then…uninstall all audio plugins and codecs you may have had installed separately. Then go to the sony setup directory,
eg-(C:..Program Files..Sony Setup..Vegas Pro 8.0) and press
“vegas80_enu” and follow the instructions.Steve Rhoden
Robert William
June 19, 2008 at 1:57 pmC:\Program Files\Sony Setup\Vegas 7.0,i see the setup and the plugins,how can i uninstall them
Steve Rhoden
June 19, 2008 at 3:01 pmNO..NO…I did not meant those, i was speaking of plugins and codecs you may have installed separately on your own or from another application….if you didnt, then follow the instructions for
maintenance!!Steve Rhoden
