Activity Forums VEGAS Pro Sony Vegas Will not import mp3s or wavs or any other audio file +
  • Sony Vegas Will not import mp3s or wavs or any other audio file +
    Posted by Josh Dooling on May 13, 2013 at 4:14 am
    recently whenever I have tried to drag and drop (or import) an mp3 or a wav sony vegas will not load it. Also when I run sony vegas a small white blank windows called sfvstserver will come up and just not do anything. But it will load audio from wmv files. Any solution?
    John Rofrano replied 13 years, 3 months ago 3 Members · 3 Replies
  • Josh Dooling
    May 13, 2013 at 5:37 am
    Little update, I reinstalled sony vegas 11 (I was using sony vegas 12) and I can drop in the same exact mp3s into sony vegas 11, but if I try to import them into sony vegas 12 they still will not import into 12. No idea what to do.
  • Bob Peterson
    May 13, 2013 at 2:43 pm
    Report the problem to Sony support, and use version 11 until it is fixed.
  • John Rofrano
    May 14, 2013 at 12:02 am
    [Josh dooling] “Also when I run sony vegas a small white blank windows called sfvstserver will come up and just not do anything.”
    Try renaming your VST Plug-ins folder or change where Vegas Pro 12.0 is looking for VST plug-ins and restart Vegas Pro 12.0 and see if that helps. It sounds like you may have a VST plug-in that doesn’t play well with Vegas Pro 12.0.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
