Activity › Forums › VEGAS Pro › Sony Vegas trouble with certain MOV files
  • Sony Vegas trouble with certain MOV files
    Posted by James Cheung on November 11, 2015 at 7:19 am
    Hi guys, novice here.
    I’ve been looking at so many threads on here about certain MOV files not opening etc and had no luck.
    A certain file I’ve been having trouble with. I’m able to import it into Sony Vegas but the video previews for about 2 seconds and then goes black screen (audio intact), then resumes normal playback about halfway through.
    Attached media info and gspot info for the mov file attached.
    The other .mov files I’ve been sent open up no problem and I’ve got no idea why this particular file is flickering like this.
    Many thanks in advance.
    John Rofrano replied 10 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Linda O’connell
    November 11, 2015 at 11:59 am
    I am not sure if this helps or not. But a while ago I was having the same problem. It turned out that the newer version of quicktime was causing the issue. I am using 7.7.6 and it works. Along with Vegas 11.
  • John Rofrano
    November 11, 2015 at 1:37 pm
    [James Cheung] “Attached media info and gspot info for the mov file attached.”
    If you want to post information you should cut and paste it into your post.
    There is no way I’m downloading and opening a ZIP file from an unknown source on my computer!
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • James Cheung
    November 11, 2015 at 3:34 pm
    Thanks Linda, I will give that a try!
  • James Cheung
    November 11, 2015 at 3:35 pm
    General
    Complete name : C:\Users\James\Desktop\officeiq-product-video.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 2.83 GiB
    Duration : 1mn 40s
    Overall bit rate mode : Variable
    Overall bit rate : 241 Mbps
    Encoded date : UTC 2015-06-12 14:06:58
    Tagged date : UTC 2015-06-12 14:08:08
    Writing library : Apple QuickTime
    Media/UUID : 4381D61A-31ED-4A03-8D25-4DE2BF566DE7
    Video
    Format : ProRes
    Format version : Version 1
    Format profile : 4444
    Codec ID : ap4h
    Duration : 1mn 40s
    Bit rate mode : Variable
    Bit rate : 240 Mbps
    Width : 1 920 pixels
    Clean aperture width : 1 888 pixels
    Height : 1 080 pixels
    Clean aperture height : 1 062 pixels
    Display aspect ratio : 16:9
    Clean aperture display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Chroma subsampling : 4:4:4
    Scan type : Progressive
    Bits/(Pixel*Frame) : 4.823
    Stream size : 2.81 GiB (99%)
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 1mn 40s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 18.4 MiB (1%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Duration : 1mn 40s
    Time code of first frame : 01:00:00:00
    Time code, striped : Yes
    Language : English
    Encoded date : UTC 2015-06-12 14:08:08
  • John Rofrano
    November 11, 2015 at 4:13 pm
    Wow, that’s a ProRes 4444 file @ 240 Mbps. Do you have a RAID array to handle the kind of footage? I’m not sure why your working in ProRes 4444 but it’s probably more video than Vegas Pro can handle with it’s 32-bit QuickTime support. ProRes 422 works fine in Vegas Pro, I’ve never tried 4444 though. This is definitely contributing to your problem. Do you need to work with that high quality?
    ~jr
  • James Cheung
    November 12, 2015 at 1:59 am
    Haha – It’s just what I’ve been given. I’ve been given some other mov files which are ProRes 422, these load fine.
    I don’t need that high quality no. What’s the best workaround for this?
    I’ve used QT Pro to export it, what compression type would you recommend I use? or is this wrong?
  • Aaron Star
    November 12, 2015 at 2:17 am
    I would see if FFMPEG can recompress that 444 footage into prores422-hq format. Should work along with the other files in Vegas after that.
  • John Rofrano
    November 13, 2015 at 12:14 am
    [James Cheung] “I don’t need that high quality no. What’s the best workaround for this?”
    Buy a Mac! Seriously, you can’t legally create a ProRes file with a Windows PC. You’ll need to convert them to a PC friendly format like CineForm AVI or Sony MXF.
    You can try FFMPEG as Aaron suggests but I’ve never used that.
    ~jr
