Activity Forums VEGAS Pro Sony Vegas Stops Responding
  • Sony Vegas Stops Responding
    Posted by Chris Poteraske on August 25, 2012 at 9:31 pm
    Extra Information
    File: C:UsersJimsAppDataLocalSonyVegas Pro11.0gpu_video_x86.log
    File: C:UsersJimsAppDataLocalSonyVegas Pro11.0dx_video_grovel_x86.log
    File: C:UsersJimsAppDataLocalSonyVegas Pro11.0svfx_video_grovel_x86.log
    File: C:UsersJimsAppDataLocalSonyVegas Pro11.0dx_grovel_x86.log
    File: C:UsersJimsAppDataLocalSonyVegas Pro11.0vst_grovel.log
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 682)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Windowssystem32amdocl.dll
    Fault Address: 0x6E7ED71F
    Fault Offset: 0x0005D71F
    Fault Process Details
    Process Path: C:Program Files (x86)SonyVegas Pro 11.0vegas110.exe
    Process Version: Version 11.0 (Build 682)
    Process Description: Vegas Pro
    This Error happens when i load a .wmv file i recorded from fraps
    I just installed a new graphics card yesterday – AMD Radeon 6700 and installed its drivers so idk what it could be.
    Mark Thompson replied 14 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Steve Rhoden
    August 25, 2012 at 9:40 pm
    Well, that seems to be an issue with the WMV format you
    recorded from fraps.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Chris Poteraske
    August 25, 2012 at 9:52 pm
    But i havent had an issue with it untill today. The format worked fine until just recently.
  • Steve Rhoden
    August 25, 2012 at 10:07 pm
    Well if thats the case, the only modification you done
    was installing a new Video Card, So the issue you are
    having lies with your new card.
    (This is so overly-recommended)..try disabling the GPU
    and see if you get different results.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Chris Poteraske
    August 25, 2012 at 11:21 pm
    Im a little hesitant to do this but.. i will do that if it is a last resort. Im thinking it has to be vegas. I can watch the video im putting into vegas just fine. But as soon as i drop ANY video into the timeline it will load and then boom! Sony vegas stops responding Immediately.
  • Kelly Basden
    August 26, 2012 at 1:25 pm
    Uninstall Vegas. Clean the registry. Reboot, reinstall, update. Clean the registry again, reboot. Try editing again. I don’t know if that will solve the problem but it would have been my first step.
    It’s all about the music.
  • Chris Poteraske
    August 26, 2012 at 5:49 pm
    Unfortunately this did nothing.
  • Steve Rhoden
    August 26, 2012 at 7:56 pm
    Very little we can assist you with, from here on
    out regarding Vegas 11 then. It has many of these consistent
    issues, with no solid solution at hand.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Mark Thompson
    August 26, 2012 at 9:06 pm
    H,
    you probably tried this but… sometimes hardware comes with outdated drivers, so you have to get the very latest from the suppliers web site. In this case: https://support.amd.com/us/Pages/AMDSupportHub.aspx
    They seem to have a tool to online check whether you have the right driver.
    As it is crashing in the Open CL driver; disabling the graphips accelerator in vegas might work for you.
    Also is your card here:
    https://www.sonycreativesoftware.com/vegaspro/gpuacceleration
