Activity › Forums › VEGAS Pro › Sony Vegas Scripting – Can’t Manage a Take. Error – Invalid Take Object
  • Sony Vegas Scripting – Can’t Manage a Take. Error – Invalid Take Object
    Posted by Naki Adil on February 14, 2019 at 3:03 am
    I want to add media from the media pool to the first track of the project that I create first. For that, I need to create a Take Object and add the media stream to it. The stream is created successfully. But there is an issue with the take that I can’t understand yet. Here is the code:
    //Adding video to the media pool
    Vegas.OpenFileDialog(“C:\\Users\\sekhfa\\Desktop\\vidoes”, “true”);
    //adding a video track to the project so i can add that the first stream of the video I added to the media pool
    var videotrack = new VideoTrack(0, “videoStream”);
    Vegas.Project.Tracks.Add(videotrack);
    //I get the stream from the media I added to the media pool
    var poolEnum = new Enumerator(Vegas.Project.MediaPool);
    var media = poolEnum.item();
    var stream = media.Streams[0];
    //I create a take from the stream
    var take = Take.CreateInstance(Project.ActiveProject, stream);
    MessageBox.Show(take.Name);
    I get this error: Invalid Take Object
    what I want eventually is to add that take to the videoevent of the video track i created.
    Edward Troxel replied 7 years, 7 months ago 2 Members · 5 Replies
  • Edward Troxel
    February 14, 2019 at 6:48 pm
    Try something more like this:
    var newEvent = new VideoEvent(cursorTimecode, stream.Length);
    videotrack.Events.Add(newEvent);
    var take = new Take(stream);
    newEvent.Takes.Add(take);
    Edward Troxel
  • Naki Adil
    February 14, 2019 at 10:08 pm
    Thank you so much!! It worked like a charm. I forgot to create the VideoEvent.
    When I add the video this way. The project resolution is not similar to the added video resolution.
    I want to make a condition depending on the resolution of the video added to the video track.
    I looked all over the API without finding it. Normally it’s under the stream properties (Its attributes).
  • Edward Troxel
    February 15, 2019 at 6:30 pm
    Are you saying you want the File – Properties to match the new event’s properties?
    Here’s part of a script of mine that sets the File – Properties. Of course you would need to change everything after the “=” signs to point to the information in your new event.
    //Set the Height and Width
    myvegas.Project.Video.Height = Convert.ToInt32(txtHeight.Text);
    myvegas.Project.Video.Width = Convert.ToInt32(txtWidth.Text);
    //Set the Field Order
    switch (cmbFieldOrder.SelectedIndex)
    case 0:
    myvegas.Project.Video.FieldOrder = VideoFieldOrder.ProgressiveScan;
    break;
    case 1:
    myvegas.Project.Video.FieldOrder = VideoFieldOrder.UpperFieldFirst;
    break;
    case 2:
    myvegas.Project.Video.FieldOrder = VideoFieldOrder.LowerFieldFirst;
    break;
    //Set the PAR
    myvegas.Project.Video.PixelAspectRatio = Convert.ToDouble(cmbPAR.SelectedItem.ToString().Substring(0,6));
    //Set the Framerate
    myvegas.Project.Video.FrameRate = Convert.ToDouble(cmbFrameRate.SelectedItem.ToString().Substring(0,6));
    myvegas.UpdateUI();
    Edward Troxel
  • Naki Adil
    February 15, 2019 at 11:46 pm
    You helped me a lot pointing me toward the properties of the video that are under The Project class. I didn’t see it.
    ProjectVideoProperties Class is what I needed.
    The problem was that when I added the video to the project it gets a 1080p resolution regardless of the video resolution.
    I found this method that fixed the issue
    Boolean MatchProjectSettingsWithMedia
    Media media
    Vegas.Project.Video.MatchProjectSettingsWithMedia(media);
    Thank you so much for your help. It’s priceless 🙂
  • Edward Troxel
    February 18, 2019 at 3:51 pm
    Glad I could help.
    Edward Troxel
