Activity › Forums › VEGAS Pro › Sony Vegas render always comes out alittle bit more darker than in preview ?
Posted by Genero Lundgren on June 7, 2012 at 2:40 pmI have had this problem for a long time and found no solution, but then again i bet some Vegas genious here on CreativeCow knows a solution so i thought id ask 🙂
Thanks in advance /G
“The hero and the coward both feel the same thing, but the hero uses his fear, projects it onto his opponent, while the coward runs. It’s the same thing, fear, but it’s what you do with it that matters.” – Cus D’amato
Eddie Mccracken replied 14 years, 3 months ago 6 Members · 11 Replies -
Steve Rhoden
June 7, 2012 at 4:06 pmWhat render formats(settings) gives you this darker than preview
results?Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Genero Lundgren
June 7, 2012 at 4:15 pm -
Steve Rhoden
June 7, 2012 at 4:39 pmCould be the player you are playing back the final rendered
video in that has its settings set darker.
Try importing back the finish video in Vegas and make a side
by side comparison with it and the un-rendered timeline in the
preview window…And see if its really darker.Steve Rhoden
(Cow Leader)
1-876-832-4956 -
Genero Lundgren
June 7, 2012 at 5:11 pmJust did what you suggested and it actually gets darkend for some odd reason… Using the brightness & contrast video FX for a comparison id say its about 0,4 more contrast. Don’t know how to explain it better than that hah.
Dave Brandt
June 7, 2012 at 8:00 pmHi,
This could be due to the way Vegas handles video and computer clorospace. See this link for more information
https://www.glennchan.info/articles/vegas/v8color/vegas-9-levels.htm
A quick way to check would be to set your color bit depth to 32 bit and render out a test and see what happens
Dave
Macbook Pro 17″ i7 2.2 8GB
iMac i7 2.8 16GB
FCP 7 FCPX Adobe CS 5.5 -
Matt Crowley
June 7, 2012 at 8:01 pmYou might find that the Vegas preview is using the 0-255 “computer RGB” system to display video that uses the 16-235 studio RGB range, so it will look less contrasty and a bit brighter.
Your player is probably expanding the 16-235 “studio RGB” video to to full computer RGB 0-255 before displaying it, so it’ll look darker and more contrasty.
I don’t know if there’s a way to make the Vegas preview handle “studio RGB” the same as most hardware-accelerated media players (and real TVs). A workaround while editing is to add the levels plugin with the “Studio to PC” preset to the output FX. You must bypass it when rendering out.
Stephen Mann
June 7, 2012 at 8:14 pmIf you aren’t previewing on a calibrated monitor, then all bets are off.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Steve Rhoden
June 7, 2012 at 9:22 pmWhere are most of your editing (projects) destined Genero?
Steve Rhoden
(Cow Leader)
1-876-832-4956 -
Genero Lundgren
June 7, 2012 at 9:30 pmI use this format to upload to Youtube and to play on a big screen TV. I don’t work for anyone i just do videos as a hobby, I could link some of my stuff if anyone is interested 🙂
G
