Activity Forums VEGAS Pro Sony Vegas’ Problem
  • Sony Vegas’ Problem
    Posted by Giulia Traballoni on January 3, 2011 at 10:52 pm
    I have recently installed sony vegas pro 10 and I now have a big problem with it: If I try to open projects made with sony vegas 9.0 it comes out this error message:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0b (Build 466)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Fault Address: 0x0076869D
    Fault Offset: 0x0036869D
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Process Version: Version 10.0b (Build 466)
    Process Description: Vegas Pro
    Process Image Date: 2010-12-20 (Mon Dec 20) 11:00:06
    I really don’t know what to do… I tried to do something following some advices founded on the net, but nothing seems to work…
    I have reinstalled it 4 times, but the problem persist…
    any suggestion? Thanks for your attention
    Giulia Traballoni replied 15 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Rasnic
    January 4, 2011 at 12:04 am
    I am not sure if you are using Windows xp or if you are using a 64 bit operating system and 64 bit Vegas (as your program reference does not contain the (x86) on the program folder).
    I had a similar issue with 10b when opening a project I had Noise Reduction applied on from Sound Forge 9. I was opening the project in the 64 bit version of Vegas and instead of it telling me that all the plugins did not load, it just crashed. Once I opened the project in the 32 bit version of Vegas 10b all was well.
    Perhaps it is something as simple as this, but I would encourage you to go back to your Vegas 9 project in Vegas 9, save it under a different name, and see what fx you have applied. Remove them one by one and try opening the new project again in 10 after each removal.
    j razz
    https://www.jrazzcreations.com
  • Giulia Traballoni
    January 7, 2011 at 11:32 am
    thank you very much for your attention.
    I have windows Vista with the 32 bit version [because the 64 bit does not work] anyway I’ll surely try to do what you suggested and I’ll tell you the result!
    thanks again.
