sony vegas pro v9, creates streaking noise
Posted by Bob Pit on July 31, 2009 at 7:00 pmIf I try to record (audio) something in vegas, it comes with a strange noise, high pitch. The voice I record comes fine though. If I save the file and try to play it from another player, I do hear the noise. If I try to playback from vegas a regular (clean) audio or video file, I hear this noise again.
I downloaded and installed the latest sound card driver from Realtek. Don’t know what else to do.
Bob Pit replied 17 years, 1 month ago 4 Members · 10 Replies -
Jeremy Rasnic
July 31, 2009 at 8:41 pmDid you record yourself the files you attempting to play back in Vegas? If so, try one that you did not record such as a mp3 of a song you purchased. Did that make any difference? If it didn’t, did Vegas ever work correctly? Before the new drivers?
Is Vegas the only program that does this?
If you are recording near speakers you may be capturing feedback. You may also want to check your microphone levels to make sure you are not peaking out.
j razz
https://www.jrazzcreations.com
Bob Pit
August 1, 2009 at 12:12 amJeremy
Vegas will cause an annoying HISS even with high quality mp3s of songs. I installed Vegas 2 weeks ago and it was always like this.
Vegas is the ONLY program that does this consistently. I think Sound Forge did this several times, but I had Vegas open too. Anyway, SF does not do it now.
I use headphones, so I am sure I am not capturing feedback.
I forgot to add: I can make the same type of recording (count from 1 to 10) from Vegas, Sound Forge and Windows Recorder. Vegas will add the annoying HISS. The other two software will make a PERFECT recording.
Jeremy Rasnic
August 1, 2009 at 2:38 amTry this: remove the audio fx that Sony automatically adds to the track (where the track controls are on the left side of the timeline). See if it is one of those in the fx chain. It is odd though that you are having this issue. I have been answering a lot of questions and using Vegas since version 4 and have never had anyone ask about this issue.
j razz
Bob Pit
August 1, 2009 at 8:40 amI did. You mean to remove the “Track Noise Gate”, “Track EQ” and “Track Compressor”, right? It did not make any difference.
This is the file recorded from sony vegas pro 9. It is distorted:
https://amra.gr/test-sounds/sony-vegas-distort.wavThis is the file recorded by Windows Sound Recorder. It is perfect:
https://amra.gr/test-sounds/windows-sound-recorder-clean.wavBoth files were recorded under the same conditions.
When I play https://amra.gr/test-sounds/windows-sound-recorder-clean.wav from winamp, Sound Forge etc, it sounds PERFECT.
https://amra.gr/test-sounds/sony-vegas-distort.wav sounds VERY distoreted, from everywhere I play it (Vegas, Sound Forge, winamp etc).
When I play https://amra.gr/test-sounds/windows-sound-recorder-clean.wav from Vegas, it does not sound as good, it sound a little distorted. But not as bad as https://amra.gr/test-sounds/sony-vegas-distort.wav.
NOW, this should be interesting. When I tried to record https://amra.gr/test-sounds/windows-sound-recorder-clean.wav from the Windows Sound Recorder, it would come out DISTORTED. I had to CLOSE Vegas, and then I was able to record it with perfect quality. Vegas must be doing something to the drivers. and affects other applications.
Bob Pit
August 1, 2009 at 9:05 amI did. You mean to remove the “Track Noise Gate”, “Track EQ” and “Track Compressor”, right? It did not make any difference.
Stephen Mann
August 1, 2009 at 3:07 pmYou are on the right track. I had a similar problem last year and it was definitely a driver conflict. Try downloading “DriverDetective” to check your drivers status.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Norman Willis
August 2, 2009 at 6:13 pmAnd perhaps also report it to Sony?
https://www.sonycreativesoftware.com/support/productsuggestion.asp
Bob Pit
August 2, 2009 at 11:09 pmBoth audio and Video drivers were outdated. After I updated them, the problem ALMOST disappeared. I have to listen carefully and still I am not 100% if there is distortion in Vegas audio.
Now I am trying to update the outdated chipset drivers, and I am having a hard time doing this.
Bob Pit
August 3, 2009 at 12:30 amMaybe I was overexcited. Maybe the problem comes and goes. But I still hear the distortion clearly. It just seems less.
Bob Pit
August 3, 2009 at 4:11 pmOk, this is what I learned:
1) You need to install first the chipset drivers, then audio driver, the video driver. This tip is from a pc technician, this is how he always sets up the pcs.
I did this and now I have very little high pitch noise. But I still have it.
2) If I set vegas to use “Direct Sound Surround Mapper”, then Sound Forge works with no problem. But vegas still has the same problem.
Now I am looking to specific compatibility issues of vegas. I may also experiment with the ASIO drivers.
