Sony Vegas Pro Audio Problems
I’ve recorded a 1 hour and 50 minute video, and I’m trying to edit it in Sony Vegas Pro 10. The part that I need starts at about 1 hour 20, and ends at about 1 hour 35. The audio works perfectly fine untill about 45 minutes into the video, when I start to play it from anywhere after that, it takes the audio from the start of the video and uses it from there for some reason. The audio works perfectly fine when I play the video, so it’s not a problem with the video itself, but with Sony Vegas. Unfortunately I discovered this after spending 4 hours rendering what I thought was a finished video. I have no idea what’s causing this, or how to fix it, the audio stream below the video looks fine and normal, but it’s just not working…
If anyone can help me figure out what is going on, I would greatly appreciate it.
