Activity › Forums › VEGAS Pro › Sony Vegas Pro 9 x64 Not Registering Mpeg-4 Xvid Codec
  • Sony Vegas Pro 9 x64 Not Registering Mpeg-4 Xvid Codec
    Posted by Chris Bach on March 11, 2010 at 1:48 pm
    Hi.
    I really want to use Sony Vegas Pro 9 on my x64 Vista, but there’s something holding me back. I am unable in achieving the right quality I’m looking for without the Mpeg-4 Xvid codec that I’ve formerly used in Vegas Movie Studio.
    I have have tried everything in my own power, so that’s why I’m coming here.
    The only thing, though, that I have yet to try is using the x32 setup instead of the x64, but I’m not sure it would make much of a difference. I have uninstalled, reinstalled, re-reinstalled several codecs and codec-packs from the web, but without luck.
    The weird thing is, the codec works in Sony Vegas Movie Studio, but not in Vegas Pro.
    Any help is greatly appreciated!
    – Chris Bach
    Jason Bausewein replied 16 years, 4 months ago 4 Members · 6 Replies
  • Douglas Spotted eagle
    March 12, 2010 at 4:17 am
    Various codec paks are one of the worst things you can do, as they can blow away “good” settings and codecs that Vegas (and other apps) register/read.
    Do you have “ignore third party codecs” enabled in Vegas?
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Chris Bach
    March 12, 2010 at 2:40 pm
    Unfortunately, I can’t seem to be able to find an option for this anywhere.
    Where is this located?
  • John Rofrano
    March 12, 2010 at 2:44 pm
    Your subject says it all:
    Your 64-bit Vegas will NEVER see your 32-bit Xvid codec.
    It will make all the difference in the world because that is, in fact, the solution! Xvid does not have a 64-bit codec and therefore cannot be used in 64-bit Vegas. You must use the 32-bit version of Vegas if you want to use codecs like Xvid or DivX which only come in 32-bit versions.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chris Bach
    March 12, 2010 at 2:46 pm
    Thank you very much. I will reinstall with x32 version. I’ll report back with the results!
  • Jason Bausewein
    March 19, 2010 at 2:12 am
    Hi Chris,
    Install ffdshow tryouts for x64 and be sure to install the VFW codec.
    https://ffdshow-tryout.sourceforge.net/download.php
    This worked for me!
    Jason
  • Jason Bausewein
    June 1, 2010 at 8:59 pm
    I found the thumbnails were not displaying correctly with ffdshow x64, Xvid64 1.3.0 works better!
    Xvid64 may be downloaded here:
    https://www.overdrivetechgrp.com/Support/Files/tabid/58/Default.aspx
