Activity › Forums › VEGAS Pro › Sony Vegas Pro 9 – No audio on imported MP4 files?
  • Sony Vegas Pro 9 – No audio on imported MP4 files?
    Posted by Jnnjkn Knknkm on August 4, 2013 at 8:16 am
    I have 64 MP4 video files around 20 minutes each I’m using for editing and at first it was only showing audio with a video track, but the entire video was black. I looked up a soloution, and downgraded my Quicktime, which fixed the video problem but now when I import any of my videos, it only shows the video, there’s not an audio track at all? (I know there’s nothing wrong with the audio, because I can play it just fine in media players and it worked before)
    Stephen Mann replied 13 years, 1 month ago 3 Members · 11 Replies
  • 11 Replies
  • Stephen Mann
    August 4, 2013 at 1:47 pm
    Use the free program mediainfo to see what codec was used.
    On the topic of codecs – NEVER install a codec pack on your editing PC. Those are for gamers and can replace the otherwise good encoding codecs installed by Vegas with inferior ones.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Jnnjkn Knknkm
    August 4, 2013 at 2:24 pm
    I have K-Lite Codec Pack and x264vfw64 installed, could they be causing the audio to not appear? (I installed them just before I downgraded Quicktime)
    I put one of the videos into Mediainfo and this is all the information I got (I’m sorry if it’s more than necessary):
    General
    Complete name : C:UsersUserDownloadsFULLMETAL ALCHEMISTFullmetal Alchemist – Brotherhood (Episodes 01-64) (JAP) (ENG-SUBS)Episode 01 – Fullmetal Alchemist.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 553 MiB
    Duration : 24mn 29s
    Overall bit rate mode : Variable
    Overall bit rate : 3 155 Kbps
    Movie name : 鋼の錬金術師
    Performer : @蒼井瞳
    Encoded date : UTC 2009-04-14 15:48:24
    Tagged date : UTC 2009-04-15 20:07:27
    Comment : 地震テロップ除去済 / MBS base and earthquake telop replaced by SBS / ※前回のは地震テロップ消しのサンプルだったのですが、 / 放流される方も少ないですし本放流に参加してみようかと。 / フィルター類一新して画質も多少なりとマシになったかな…
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 24mn 29s
    Bit rate : 2 959 Kbps
    Maximum bit rate : 15.7 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.079
    Stream size : 518 MiB (94%)
    Writing library : x264 core 67 r1140_EXPERIMENTAL
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / me-prepass=1 / psy_rd=0.5:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,8 / chroma_qp_offset=-2 / threads=6 / thread_queue=6 / nr=0 / decimate=0 / mbaff=0 / fgo=1 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=240 / keyint_min=1 / scenecut=70 / rc=crf / crf=22.0 / qcomp=0.70 / qpmin=20 / qpmax=50 / qpstep=10 / vbv_maxrate=16500 / vbv_bufsize=16500 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1:-0.40:7.00:1.00:1.00:1.00 / aq2=1:0.30:15.00
    Encoded date : UTC 2009-04-14 12:52:26
    Tagged date : UTC 2009-04-14 15:48:41
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 24mn 29s
    Bit rate mode : Variable
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 33.0 MiB (6%)
    Language : Japanese
    Encoded date : UTC 2009-04-14 15:48:38
    Menu
    00:00:00.000 : Avant
    00:00:58.767 : Opening
    00:02:28.690 : A part
    00:10:54.821 : B part
    00:22:26.428 : Ending
    00:23:56.685 : Next
  • Stephen Mann
    August 4, 2013 at 2:41 pm
    K-Lite is the worst at screwing up Vegas. I would uninstall K-Lite and reinstall Vegas.
    I am an advocate of frequent system and component updates with few exceptions. Quicktime is one that I never update because it appears that every QT update also incorporates a host of new incompatibilities with Vegas (Premiere and Avid users have the same complaint). But you must have Quicktime installed to edit some MP4 files.
    I never edit AVC files, so I am the wrong source of Quicktime advice. Perhaps someone else can chip in with a recommendation of a working QT version. Once it is working on your PC, don’t upgrade QT.
    Steve Mann
    http://www.mmdv.com
  • Jnnjkn Knknkm
    August 4, 2013 at 2:56 pm
    Sorry if this is a stupid question, but if I uninstall Sony Vegas, will I be able to reinstall without entering a serial code? Because I’ve had SV for years and I have no idea what my serial code was.
  • Stephen Mann
    August 4, 2013 at 3:49 pm
    You don’t have to uninstall Vegas, just install it again. Your serial key can be found in the Sony website under “My Account” and “My Software”.
    https://www.sonycreativesoftware.com/myaccount/home
    Steve Mann
    http://www.mmdv.com
  • Jnnjkn Knknkm
    August 4, 2013 at 4:45 pm
    Thanks. I uninstalled K-Lite and reinstalled Vegas, but the audio problem is still there.
  • Stephen Mann
    August 4, 2013 at 7:35 pm
    Post one of the shorter videos and I’ll see what happens here.
    Steve Mann
    http://www.mmdv.com
  • Rick Shorrock
    August 5, 2013 at 2:09 pm
    It says your audio is ID 2? Is that video ripped from a Region 2 DVD? If so, that might be your problem. Guy, help me out.
  • Stephen Mann
    August 5, 2013 at 4:49 pm
    I’m pretty sure that the audio doesn’t have a region code in the metadata like video does. Besides, in the OP, he said that he had audio but no video until he upgraded QuickTime, and now he has video and no audio.
    Chloe – can you play the MP4 file in Quicktime?
    Steve Mann
    http://www.mmdv.com
  • Jnnjkn Knknkm
    August 6, 2013 at 8:55 am
    Yes the video and audio both play when I open it in Quicktime Player.
