Sony Vegas Pro 8- Audio seperation?
Posted by James Mauldin on September 19, 2008 at 5:02 amHi, I was just wondering if Sony Vegas Pro 8, had some way of separating an audio (bass & treble), from 1 audio track, because I’m trying to make this one songs bass or beats louder than the lyrics.
In case your wondering this is the song
https://www.youtube.com/watch?v=-zdxnWIB4P8John Rofrano replied 18 years ago 3 Members · 10 Replies -
John Rofrano
September 19, 2008 at 11:01 amCopy the audio track and use the Track EQ to cut off the bass on one copy and the treble on the other.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
James Mauldin
September 19, 2008 at 1:35 pmThank you so much, I would have never found this out on my own! XD
James Mauldin
September 19, 2008 at 1:43 pmWait, how exactly do I get to Track EQ, I have no idea where to go.
Terry Esslinger
September 19, 2008 at 4:55 pmClick on the Fx icon in the track header. You will notice when the Fx box opens that there are by default three fx already applied but set to do nothing. Click on the Track Eq and it will open the controls for using it.
James Mauldin
September 20, 2008 at 4:30 amWhen I click that icon all I get is this:
https://img216.imageshack.us/img216/6985/1111pm8.jpg -
John Rofrano
September 20, 2008 at 1:11 pmThen you have manually changed your default track properties in Vegas because they usually come up with 3 standard FX. No worries, just click on Sony in the Plug-in Chooser window and then click on Track EQ and press the Add button and then OK button.
~jr
James Mauldin
September 20, 2008 at 10:34 pmOk I click on Sony but nothing is there…
https://img146.imageshack.us/img146/7132/1112id2.jpg -
John Rofrano
September 20, 2008 at 10:48 pmIt looks like you have a corrupt installation. You are missing all of the Sony plug-ins. I would completely uninstall and re-install. If they still don’t show up, I would contact Sony technical support.
~jr
James Mauldin
September 21, 2008 at 3:16 amOk I got everything fixed now, but how exactly do I use the Track EQ too cut the treble and bass, I’m pretty confused.
https://img205.imageshack.us/img205/3172/11123gj5.jpg -
John Rofrano
September 21, 2008 at 12:07 pmRemember you need to make a copy of the track. On the treble copy, pull (1) all the way down to the bottom. (1) is already set as a Low Shelf so it will cut the bass.
On the bass copy, change (1) to High Shelf and again pull it all the way down to the bottom. This will cut all of the highs (treble) and leave you with just the bass.
In both cases adjust the Frequency to the point at which you want to start cutting treble or bass.
~jr
