Activity › Forums › VEGAS Pro › Sony Vegas Pro 13 – Cant Add Music
  • Sony Vegas Pro 13 – Cant Add Music
    Posted by Morgan Grimshaw on August 10, 2016 at 6:12 pm
    whenever i try to add any music into Sony Vegas Pro 13 it says it cant acces this file and to check i have access to it, but i can open MP3 files but not files like m4a. How can i open M4A files? Thanks in advance!
    Graham Bernard replied 10 years, 1 month ago 3 Members · 3 Replies
  • Graham Bernard
    August 10, 2016 at 7:13 pm
    Yah got iTunes? Stick through that and convert to MP4.
    * Grazie
  • John Rofrano
    August 10, 2016 at 8:42 pm
    [Graham Bernard] “Yah got iTunes? Stick through that and convert to MP4.”
    I’m not sure if iTunes will convert to MP4 directly but Graham on the right track…
    [Morgan Grimshaw] “How can i open M4A files?”
    If they contain Digital Rights Management (DRM) you can’t open them in Vegas Pro because it doesn’t support DRM. Early iTunes music all had DRM. Now you can buy iTunes music without it.
    If you need a non-DRM version, and the files are from iTunes and you are the owner, you can open the music in iTunes and ask iTunes to burn them to CD. Then you can import from the CD using Vegas Pro. Maybe there is a more direct way as Graham suggests but this has worked for me win the past.
    If you do not have iTunes and you are not the owner, then you are out of luck.
    BTW, this is one of the reasons I love my Mac. I can open any of my iTunes music in Final Cut Pro X without any problems. There is a beautiful simplicity in a system where everything just works together. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Graham Bernard
    August 11, 2016 at 2:01 am
    [John Rofrano] “I’m not sure if iTunes will convert to MP4 directly but Graham on the right track…”
    John, you’re correct. My mistake. Our chum asked for MP3 not MP4. I saw this page where this conversion is done through iTunes : https://www.digitaltrends.com/computing/how-to-convert-m4a-files-to-mp3-format/
    * Grazie
