Activity Forums VEGAS Pro sony vegas pro 12 wont load my project
  • sony vegas pro 12 wont load my project
    Posted by Bar Levy on February 27, 2015 at 11:27 am
    hello guys, recently i was working on my project and everything was fine after i did a save and i reboot my pc.
    after the reboot i was getting this error: https://snag.gy/7XkmU.jpg
    any ideas?
    Bar Levy replied 11 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • Roger Bansemer
    February 27, 2015 at 12:29 pm
    Instead of opening your project from within Vegas, try opening your veg file from windows explorer instead. I had that same problem once.
    Of course the other thing is to rename your backup file and load that.
    The backup file has the same name as your original veg file but ends in .bac
    Roger Bansemer – PaintingAndTravel.com
  • Bar Levy
    February 27, 2015 at 1:16 pm
    i have try everything that i could, even search so much on the forum and sadly, aint find anything.
    maybe its a codec issue? since i re installed some codecs.
  • Mike Kujbida
    February 27, 2015 at 1:22 pm
    Just a follow up to Roger’s excellent suggestion. The backup file has a .bak extension. Move it to a different folder, rename it from (for example) myvideo.veg.bak to myvideo.veg and try opening that one. Good luck.
  • Bar Levy
    February 27, 2015 at 1:23 pm
    not working
  • Bar Levy
    February 27, 2015 at 3:27 pm
    i allready try all of what you all say, i even search alot on the forums(spend like 2H) no luck.
    i am really frustrated right now since i worked over 3 monthes on this video…..
  • Dave Osbun
    February 27, 2015 at 6:31 pm
    Are some of the files used on the project on an external drive, or where they originally on an external drive?
    Dave
  • Bar Levy
    February 27, 2015 at 6:35 pm
    i got only 1 driver and i didnt move anything even after that happend.
  • Tyson Onaga
    February 27, 2015 at 10:38 pm
    If you know the folder(s) where your media is located, rename it (them).
    E.g.:
    D:\Work\theProject\Media
    to:
    D:\Work\theProject\MediaNew
    Try open the .veg. Vegas should complain it can’t find any of the media. Choose Specify a New Location or Replacement File. Do each media file one at a time (using the new location) and see if Vegas crashes on a particular file.
  • Bar Levy
    February 28, 2015 at 7:40 am
    still not working
