Activity Forums VEGAS Pro Sony Vegas Pro 12 MainConcept AVC – Can’t Change Constant Bitrate
  • Sony Vegas Pro 12 MainConcept AVC – Can’t Change Constant Bitrate
    Posted by Jay Anderson on July 12, 2013 at 7:44 pm
    Hello,
    I’ve come across a problem in rendering.
    In Mainconcept AVC/AAC Internet 720p, I want to render my videos at a constant bit rate of 6,000,000 bitrate but there is no option for it. I can only select preset bit rates. The closest is 4,000,000 which is too low (I notice the quality drop) and 10,000,000 which is too high (Excellent quality). Is there any way for me to edit that option to use 6,000,000 instead? I’ve searched far and wide on google and found no solution. This should be a really simple task, but I just can’t figure out how to do it.
    Note:
    Don’t ask me to:
    -use Variable bitrate, I am not going to use it, period.
    -change variable bitrate average to 6,000,000 and maximum to 6,000,000
    -switch my encoder from Mainconcept AVC/AAC to something else
    -anything that has nothing to do with editing the constant bitrate
    Stephen Mann replied 13 years, 1 month ago 2 Members · 1 Reply
