Sony Vegas pro 11 Not recognizing Avi
John Rofrano replied 13 years, 10 months ago 4 Members · 17 Replies
Heather Pumphrey
November 23, 2012 at 6:20 amyea it works in windows media, dixv, kmp, and vlc players
John Rofrano
November 23, 2012 at 1:00 pm[heather pumphrey] “yes it is 64 bit”
My questions was, “are they all 64-bit?” have you switched from using 32-bit Vegas to 64-bit Vegas? That might explain why they don’t work now.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Heather Pumphrey
November 23, 2012 at 6:38 pmOnly sony vegas pro 11 is the 64 bit, I used that on my desktop, while the 32bits are used on my mini laptop. So only one is 64 bit, after all my desktop doesn’t like the 32 bit and only works with the 64 bit.
John Rofrano
November 23, 2012 at 6:49 pm[heather pumphrey] “Only sony vegas pro 11 is the 64 bit, I used that on my desktop, while the 32bits are used on my mini laptop. So only one is 64 bit, after all my desktop doesn’t like the 32 bit and only works with the 64 bit.”
That could be why it doesn’t work with Vegas Pro 11.0 64-BIT. You need to have the correct 64-bit codecs installed in order to use the video in 64-bit Vegas. I’m guessing that you only have the 32-bit codec which will not work with the 64-bit version of Vegas Pro. This is probably why it works on your laptop and not your desktop.
~jr
