Activity Forums VEGAS Pro Sony Vegas Pro 11 Not Opening!
  • Sony Vegas Pro 11 Not Opening!
    Posted by Israel Yang on December 30, 2013 at 1:13 am
    Ok, so I’ve been using Sony Vegas for about a year and today it just decided to not open. I click on the icon and the menu thingy loads that shows you how much it has left to open. So that bar goes until it reaches “Adding MIDI MME Support.” The only solution to this problem was to go into Safe Mode. That is where it would open with no problem. I need it to work again ASAP.
    My PC is pretty shit, but it can run the program.
    Any help would be very much appreciated!
    John Rofrano replied 12 years, 9 months ago 2 Members · 1 Reply
  • John Rofrano
    December 30, 2013 at 2:18 pm
    One option would be to reset Vegas to all of the defaults. You do this by holding down the CTRL+SHIFT when you double-click the icon and answering YES to the question “Do you want to reset all Vegas Pro preferences to default values?“. You will loose any changes you may have made in your preferences but it may get it to at least start up.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
