Activity Forums VEGAS Pro Sony Vegas pro 11: No sound after render
  • Sony Vegas pro 11: No sound after render
    Posted by Nicolas Strybol on November 25, 2011 at 11:22 pm
    hey everyone,
    My name is Nicolas and I have been having a very annoying issue with sony vegas pro 11 trial version.
    So i make videos on my friends channel on youtube. So i went and found settings for youtube (Here’s the link: https://www.youtube.com/watch?v=OMP1DorIheI). These work great!
    However a few days ago, i started having this problem, the rendered videos(in mp4) have no audio, even thought before rendering everything is fine. So i did the following tests:
    Rendering a fragment of the video works
    rendering a fragment of another video works
    Rendering a complete different video works but may not work afterthat
    Muting the video and rendering the audio in MP3 works
    rendering the same video in a different extension works
    could you shed some light on this issue? it’s very troublesome and im running behind my upload schedule
    Thank you in advance
    Howard Harkness replied 9 years, 10 months ago 10 Members · 16 Replies
  • 16 Replies
  • Stephen Crye
    November 26, 2011 at 5:34 pm
    Hi;
    Just a stab in the dark, but I have heard seen vague references to problems with .mp4 audio and Vegas being caused by some bizarre interaction with newer/updated installations of Quicktime (sometimes in conjunction with iTunes updates). Have you done anything with Quicktime or iTunes on the computer in between the time it worked and when it started to fail?
    Steve
    Win7 Pro X64 on Dell T3400, MultiTB SATA, 8GB RAM Vegas 10e x64 DVDA 5.2(build 133) Sony HDR-CX550V
  • Malcolm Matusky
    November 26, 2011 at 6:34 pm
    I recently had issues with VP11 and rendering, editing was fine, but I had to uninstall VP11 and all my codecs, then reinstall VP11 then I was able to render my project without incident.
    Malcolm
    http://www.malcolmproductions.com
  • Nicolas Strybol
    November 26, 2011 at 7:27 pm
    i already have installed the latest quicktime (before the problem occured) and i don’t have Itunes.
    also forgot to mention im using fraps to record the ingame footage.
  • Nicolas Strybol
    November 27, 2011 at 7:28 pm
    Ok, i reinstalled the latest quicktime just to be sure.
    Still no luck, here an image:
    now the 2 top tracks are UNEDITED video/audio, i just put them together and render.
    The 2 bottoms ones are the rendered video/audio of the 2top ones.
  • Stephen Crye
    November 28, 2011 at 5:06 am
    Hi Nicolas;
    I’d like to have a look at the settings you are using for the .mp4 render. In your first post, you wrote:
    “…So i went and found settings for youtube (Here’s the link: > ” , but the link does not show up in Creative Cow.
    Please take a snapshot of the Vegas “Render As” screen where you select the codec, and then also the Custom screens, both the video tab and the audio tab, and post them for us.
    Below are examples of the default Vegas Sony AVC render – this will work for YT, even though it will produce a file that is large and not ideal for uploading. As a test, try those same settings and let us know if the rendered file has sound. Also, you mentioned that rendering with a different choice of codec worked; which one(s) have you tried that worked?
    Steve
  • Nicolas Strybol
    November 28, 2011 at 7:25 am
    ok so here are the pictures:
    and the tests i did were with PSP memory stick (I dont remember which 1 exactly)
    extra note: I uninstalled quicktime and i’m trying a new test: rendered the audio track in MP3(im now rendering the video in my custom format with the rendered audio)
  • Nicolas Strybol
    November 28, 2011 at 2:53 pm
    hey stephen,
    the last test i did was a success! The audio is there after rendering.
    thank you for your help in this matter.
  • Stephen Crye
    November 28, 2011 at 10:34 pm
    Wow … I am happy but puzzled. I logged in right now to post that I was completely baffled and to ask the Cow Brain to jump in and help, then I saw your post that it had worked!
    I hope it continues to work, but something strange is happening… if it fails again don’t give up.
    We can always try more things.
    Steve
  • Kokoro Hoshiko
    December 29, 2011 at 11:44 pm
    hi, im really lost. after rendering the same thing happen the the other user. there’s no audio when i open the movie on window media player.can you please help me. i used this youtube link to help me render is in HD for youtube: https://www.youtube.com/watch?v=jfY35kKHR3k and i really need to upload it on new years day or new years eve (2012)
  • Kristoffer Hansen
    January 23, 2012 at 9:16 pm
    I had the same problem, but found the checkmark on the soundpane van not set. So I created a new custom copy of the dvd setting with the sound enable. works as it should now after a few hours of banging my head against the keyboard….constructevely
