Activity Forums VEGAS Pro Sony Vegas Pro 11 cleanest and crispest rendering settings then into Sorenson Squeeze
  • Sony Vegas Pro 11 cleanest and crispest rendering settings then into Sorenson Squeeze
    Posted by Joe Bigornia on February 14, 2012 at 3:49 am
    Need some input. I need to know what would be the best way for me to render out of Sony Vegas Pro 11, .avi?
    Also if anyone is familiar with SOrenson Squeeze I would like to know the best settings to render out as well. I have been using the Film 1080p HD format to render out of SS.
    Any info would be Great, Thank you
    Carl Alessi replied 14 years, 6 months ago 2 Members · 1 Reply
  • Carl Alessi
    February 14, 2012 at 4:23 pm
    Personally, I always use “Uncompressed AVI” before rendering to Flash from Squeeze. However, I do find that my audio track has to be adjusted in the source AVI to match the audio settings Squeeze will use (in my case, it’s 22,050 Hz, Bit depth of 16 and Mono…but your mileage may vary, depending on your desired output). If I don’t do that, my audio will come out horribly distorted and over-modulated.
