Sony Vegas Pro 10 not detecting my camera
Posted by Robbie Mcwilliams on December 14, 2013 at 1:47 amMy subject line explains my problem, I am trying to capture video from a Sony HVR-HD 1000P which you have to do using Firewire. My Firewire card works, did diagnostics, plugged something else and all good.
I have tried using other software like movie maker and nothing sees the camera. Any tips?
Thanks guys and gals
Graham Bernard replied 12 years, 8 months ago 3 Members · 6 Replies -
Nigel O’neill
December 14, 2013 at 5:27 amIt could be a driver issue or a hardware issue. Hopefully it is a driver issue.
Please update your signature with your system specs including Vegas version. It will help to diagnose the issue.
It is also possible the onboard firewire circuit in the camera has been damaged if other devices are being recognised but not the 1000P. I had a couple of Sony FX1’s get damaged this way. One was replace under warranty. Sony refused to replace the other. The board (then) cost over $1000 to replace.
Has this camera ever worked before with this computer?
Are you using a DV line protector between your PC and the camera?
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Graham Bernard
December 14, 2013 at 5:37 amRunning Windos 7? I needed to apply the Legacy driver for my FireWire card. I did this from Device Manager.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Nigel O’neill
December 14, 2013 at 9:18 amGrazie
I hope it is a driver issue, although the OP does mention it recognises other firewire devices. It’s quite easy to short out the onboard (camera) firewire port.
Here is an old thread that discusses the issue, which I became aware of when I bought my Z1P/FX1:
https://forums.creativecow.net/thread/162/865033
Graham Bernard
December 14, 2013 at 9:59 amPhil, before you can ascertain that you’d need to ask what other devices had worked with the f/w.
G
Nigel O’neill
December 14, 2013 at 1:24 pm[Graham Bernard] “ask what other devices had worked with the f/w.”
Does the camera get recognised on other computers?
Graham Bernard
December 14, 2013 at 3:07 pmDoes the camera get recognised on a pre-win7 computer?
G
