Activity › Forums › VEGAS Pro › Sony Vegas preview windows doesn’t work
  • Sony Vegas preview windows doesn’t work
    Posted by Martijn Peek on October 17, 2009 at 5:00 pm
    Hi
    When i try to preview a video that is in the project media by clicking on it, i hear the audio of that clip but i don’t see any footage in the preview screen. I’m experiencing this issue since my upgrade from Vegas Pro 8 to Vegas Pro 9.
    My system specs:
    Core i7 920 @ 2,67
    MSI X58 Pro SLi
    OCZ Gold XTC 3GB in triple channel
    2x ZOTAC 8800GT in SLI formation
    Has anyone got a sollution to this problem?
    Jon Humphreys replied 16 years, 5 months ago 7 Members · 9 Replies
  • 9 Replies
  • John Rofrano
    October 17, 2009 at 6:03 pm
    What format/codec are the source video files? Do you have that codec installed? (can’t tell if this is a new PC or same as your Vegas pro 8.0 PC) Vegas Pro 9.0 doesn’t come with the CineForm codec anymore. Are they CineForm files?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Martijn Peek
    October 17, 2009 at 6:09 pm
    I’ve been using Vegas 8 for months on this system, so that can’t be the problem. The files i tried to preview are .AVI files, containing footage from my MiniDV camera and it was put on the PC using the Sony Video Capture software. Besides that it doesn’t matter what kind of media i try to preview, even the gradients generated by Vegas itself won’t preview in the preview windows.
  • Mike Kujbida
    October 17, 2009 at 7:52 pm
    My guess is that you accidentally enabled (clicked on) the Split Screen View icon.
    It’s the dual-shaded circle at the top left of the Preview window.
  • John Rofrano
    October 19, 2009 at 12:58 am
    Yea, specifically if you select Clipboard and Select All you would see black if there was no video on the clipboard regardless of what was on the timeline.
    ~jr
  • Keanu Vincent
    February 19, 2010 at 5:13 pm
    Hey, i have the same problem and i know it’s because i clicked that dual shaded circle, so ive been clicking it again and clicking everything on the dropdown arror to try and fix it but its still black? Any help would be much appreciated thanks 🙂
  • Douglas Spotted eagle
    February 19, 2010 at 6:20 pm
    If you are trucly vexed about getting the image back, shut down Vegas, hold CTRL+SHIFT and restart Vegas. This will reset all Vegas parameters back to factory settings. you’ll lose any preference settings.
    But…you should be able to see the halfmoon/circle is highlighted/engaged or not.
    There are two issues at play here, one is preview window/codec, the other *might* be preview window and clipboard/pre-edit.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Keanu Vincent
    February 19, 2010 at 6:26 pm
    Thank you very much 🙂
  • Michael Swindler
    March 17, 2010 at 8:22 pm
    I found this thread looking for a solution to this problem. Thankfully, I think I found the answer on my own…
    Go to the trimmer window (Alt+2 to open it if it isn’t already) and turn off the button for “Show Video Monitor”. It is a blue box flanked by two vertical black lines, should be the third from the right on the Trimmer toolbar. Once I did this, my video previews from the Project Media and Explorer windows worked just fine.
    Hope that helps…
  • Jon Humphreys
    April 16, 2010 at 11:37 pm
    Michael Swindler was correct! Disabling “Show Video Monitor” fixed this issue. Thanks for restoring my sanity.
