Sony Vegas: Preview settings mess with crop
Hi, i’ve been editing a video and I had added a ton of effects to it. Because of this, my video lags a lot when I preview it. I looked at a lot of youtube videos that require you to change the sony vegas settings to help stop the lag. They all worked and i’m not sure if they ended up causing my video to glitch. I have been editing my video in draft mode the entire time, even before it started lagging. I was almost done with my video and I was adding text. I wanted to see how to the text would look in the actual video, and not how it looks pixelated. Once i changed the preview settings, the crop on my video went all weird. The crop isn’t messed up when i’m on draft, but when I change it to preview or anything higher than that it messes it up. I have tried using the pan and crop to adjust the video back to the way it was, but it doesn’t help. I also completely rendered the video and the crop is still weird. I have a video showing what it does, please help?
