Activity › Forums › VEGAS Pro › Sony Vegas Plat 9 crashing.
  • Sony Vegas Plat 9 crashing.
    Posted by James Phenicie on December 20, 2010 at 8:50 pm
    I’m working on a video story in Sony Vegas Platinum 9 ( have the latest update-b) and I am at the 6:00 min mark adding clips. The system freezes and crashes. I was working on another computer and the same thing happened. The selected clips for the documentary are on a HP external hardrive (USB).
    I have not finished editing, and the overall project will be around 6 minutes. Any one experience this issue… what to do to overcome it?
    Regards.
    Stephen Mann replied 15 years, 9 months ago 2 Members · 3 Replies
  • Stephen Mann
    December 21, 2010 at 5:02 am
    If the crash occurs at the same point in the timeline, especially on a second machine, I would likely suspect that you have bad media. Try rendering “around” the crash point.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • James Phenicie
    December 21, 2010 at 11:05 pm
    Thanks… I’m not at the rendering point… I’m still working on adding clips to the timeline… I re-edited the clips and now am back to the 6 min mark…
    each time I go into Explore and click on a file, I get an error message: an Exception has occurred and get this code….
    Vegas Movie Studio Platinum 9.0
    Version 9.0b (Build 92)
    Exception 0xC0000005 (access violation) WRITE:0x24397E8 IP:0x7814500A
    In Module ‘MSVCR80.dll’ at Address 0x78130000 + 0x1500A
    Thread: VideoRender ID=0xE9C Stack=0x90CF000-0x90D0000
    Registers:
    EAX=7ddf1420 CS=001b EIP=7814500a EFLGS=00010212
    EBX=00001400 SS=0023 ESP=090cf73c EBP=090cf744
    ECX=00000500 DS=0023 ESI=7ddf0020 FS=003b
    EDX=00000000 ES=0023 EDI=024397e8 GS=0000
    Bytes at CS:EIP:
    7814500A: F3 A5 FF 24 95 24 51 14 …: 78 90 8B C7 BA 03 00 00 x…….
    Stack Dump:
    090CF73C: 7DDF0020 7DDF0000 + 20
    090CF740: 024397E8 02350000 + E97E8
    090CF744: 000002D0
    090CF748: 01507F78 01320000 + 1E7F78 (vegasmoviestudiope90k.dll)
    090CF74C: 024397E8 02350000 + E97E8
    090CF750: 7DDF0020 7DDF0000 + 20
    090CF754: 00001400
    090CF758: 00000000
    090CF75C: 00001400
    090CF760: 020B6BC0 01FE0000 + D6BC0
    090CF764: FFFFEC00
    090CF768: 00000000
    090CF76C: 00000000
    090CF770: 00000000
    090CF774: 01400000 01320000 + E0000 (vegasmoviestudiope90k.dll)
    090CF778: 00B40000 00400000 + 740000 (VegasMovieStudioPE90.exe)
    > 090CF784: 01400000 01320000 + E0000 (vegasmoviestudiope90k.dll)
    > 090CF788: 00B40000 00400000 + 740000 (VegasMovieStudioPE90.exe)
    090CF78C: 00000000
    090CF790: 00000000
    090CF794: 00000000
    090CF798: 00000000
    > 090CF7B0: 01400000 01320000 + E0000 (vegasmoviestudiope90k.dll)
    090CFFF0: 00000000
    090CFFF4: 005A1980 00400000 + 1A1980 (VegasMovieStudioPE90.exe)
    090CFFF8: 0290BB30 02890000 + 7BB30
    090CFFFC: 00000000
    It doesn’t matter which file I try to access, the Error message occurs. This is driving me nuts…
  • Stephen Mann
    December 22, 2010 at 12:08 am
    Everything after “access violation” is of value only to the original programmer, and then only in controlled conditions.
    We have all seen access violations occur since we took ownership of our first x86 PC’s. The infamous “Bluescreen”, application crashes, it doesn’t really matter, access violations are all over the place. For any of you that remember the good old Windows 9x days, a General Protection Fault and Invalid Page Fault are basically the same thing (and a segmentation fault too). To many people, the phrase ‘access violation’ is synonymous with “crash”. But what exactly is an access violation?
    To put it simply, an access violation occurs any time an area of memory is accessed that the program doesn’t have permission to access. This can be due to bad code, faulty RAM or even a bad device driver. It really doesn’t matter who the culprit is, the root issue is the same.
    The free program: Prime95, available at https://files.extremeoverclocking.com/file.php?f=103 will torture test your PC. If you have bad RAM or a heat sensitive component, this program will find it. While you may not be overclocking, Vegas is very processor intensive – more than Premiere. If you have a PC on the edge of stability, Prime95 will push your PC hard. If you can run Prime95 for an hour, then your PC is probably not the problem.
    If you have a problem driver, I recommend running Driver Detective from https://www.drivershq.com/ (Actually a good plan is to run Driver Detective periodically. I doesn’t do anything to your installed drivers unless you tell it to.)
    Steve Mann
    http://www.mmdv.com
