Activity › Forums › VEGAS Pro › Sony Vegas Not Responding
  • Sony Vegas Not Responding
    Posted by Chrisabel Noyes on December 2, 2011 at 4:03 pm
    Hey,
    I wondering if you could help me? Am having a problem with sony vegas and it driving me mad!
    I use sony vegas pro 9.c, 64 bit (new blue effect installed)
    Windows 7, 64 bit operating system
    8.00 GB of Ram
    Intel (R) Core (TM) i5-2500 CPU@3.30GHz 3.30 GHz (whatever that means)
    I’ve used this version of vegas for a long time, as i have found this to be the most realiable version. But for some reason all of a sudden my projects just freeze up (thought it was just the one project, but i tried others and the same problem occured)i have to click on the cross in the corner, and then i get the error message, ‘Vegas is not responding. I can’t understand why this is happening? When everything has been working before. The files i use are mainly AVI and WMV, and my projects are between 3-4 mins long. I’ve tried solutions such as, making sure the project setting match the original files, copy and pasting the orignial project, into a new project, which at first seemed to work, but then the problem started again! I’ve checked the codec with Gspot, and they are all installed. Apart from the WMV, with were originally MKV files that i converted to WMV (but again, i’ve been working with these files for sometime and had no problem)
    https://imageshack.us/photo/my-images/810/gspot.png/
    Some say it due to lack of space on your PC, but my computer is 5 months old and was built especially for video editing.
    The not responding issue isn’t always consistent. It can happen as soon as i open a project, yesterday i worked on it for 2 hrs until it stopped responding, then after that it was all the time. I can’t playback a whole project because it freezes up half why through (but the music still plays). It seems to work best when i work on smaller sections, but even that freezes up eventually too.
    Any ideas? Do you need more information? Bare in mind am not to computer literate!
    Thanks in advance
    Christabel
    Nigel O’neill replied 14 years, 9 months ago 5 Members · 15 Replies
  • 15 Replies
  • Stephen Mann
    December 2, 2011 at 5:51 pm
    Describe your “freeze”. Do you just get the spinning icon or a white screen?
    When it freezes, go to Windows Start and enter “resmon”. In the resource monitor under either the CPU or Memory tab, find Vegas in the Processes windows. Right click on it and select “Analyze Wait Chain”
    If the process is waiting on something, there will be a list of threads waiting for something to happen. Unfortunately, the thread number doesn’t help us here. But you can terminate one or more of the waiting threads and maybe, just maybe, Vegas will give you a more meaningful error message.
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Chrisabel Noyes
    December 2, 2011 at 6:31 pm
    I get both. First i get the spinning wheel, then i click the cross in the top right hand corner, then i get the white screen!
  • Chrisabel Noyes
    December 2, 2011 at 6:38 pm
    I did what you suggested, and this is the message that appears.
    https://imageshack.us/photo/my-images/13/resmon.png/
    Christabel
  • Tyson Onaga
    December 2, 2011 at 8:04 pm
    I’ve seen Vegas 8.x, 10.x have the same issues. Whenever FileIOSurrogate.exe (from Sony) has a problem it appears to be a HD issue which is the common cause.
    First, I’d get Process Explorer from SysInternals.
    https://technet.microsoft.com/en-us/sysinternals/bb896653
    This can show you all the process, subordinate DLLs, threads, etc. … more detail than you can throw a stick at. You can easily see if Vegas or something spawned from Vegas is “dead”. You can then kill Vegas from here.
    Second, I’d run a HD scan on your disks.
    chkdsk [dr:] /v/f
    should suffice.
  • Stephen Mann
    December 2, 2011 at 8:12 pm
    Like I said, the thread that Vegas is waiting for is meaningless in this context. But if you kill the thread then Vegas will resume, and if you’re lucky, crash with a more meaningful error message.
    Steve Mann
    http://www.mmdv.com
  • Chrisabel Noyes
    December 2, 2011 at 8:13 pm
    Thanks for your help, but can i just say, that am doing what your suggesting, but i don’t really understand? Am sorry! This is what i get when i run process explorer.
    https://imageshack.us/photo/my-images/855/processr.png/
    what does this all mean?
    and how would i run a check on my HD files?
    Thanks.
  • Chrisabel Noyes
    December 2, 2011 at 8:26 pm
    I think i did that, i went to resmon, analyse wait chain, and checked the boxes, and Vegas just closes. Should i be doing something else?
  • Steve Rhoden
    December 2, 2011 at 8:57 pm
    In the meantime i would recommend you download and
    install the last release of Vegas 9 (9.0e).
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Tyson Onaga
    December 2, 2011 at 9:22 pm
    From your image, you have two instances of Vegas running. If you don’t see two copies of Vegas in your task bar, something’s wrong (i.e., one of them has crashed; you don’t have a UI to interact with but it is still resident in memory).
    If you have had any applications shut down abnormally or if Windows blue-screen-ed on you, I’d run a HD scan. Open a command box and type:
    chkdsk c: /v/f
    Check each HD you have.
    Reboot. Start a fresh copy of Vegas. Process Explorer should only show one instance of Vegas. Create a new project and insert one of your previously used avi or wmv files. Save the project. Close and reopen it. You shouldn’t have any problems.
    Open one of the projects that you had a problem with. Any problems? If you do, open one of your backups (you did make backups, yes!?) to see if it is the file or some changes you made since your last “edit”.
    BTW … I’ve also seen Vegas die where the splash screen is up and it is on the “File I/O …” initialization. In those cases, I’ve found “oprhaned” File I/O Surrogate.exe hanging around (using Process Explorer). When I kill them and Vegas, a restart of Vegas almost always succeeds.
  • Chrisabel Noyes
    December 2, 2011 at 9:53 pm
    Can i just say thank you all for helping! May not understand 100% but am getting there!
    I’ve checked on process explorer again, and i only have one copy of vegas open. When i did print screen, i think i did have two copies open at once, one was frozen and the other one working.
    I went to chkdsk c: /v/fm, and it started checking files, how do i check my individual HD files?
    If i upgrade to vegas 9.e, is there a chance the problem will still persist?
    Sorry to be a pain!
