Activity › Forums › VEGAS Pro › Sony Vegas Not Responding
  • Chrisabel Noyes
    December 2, 2011 at 9:57 pm
    When you say ‘Backup’, by that, do you mean, just saving two copies? because i always do that. Or is there something else i should be doing?
  • Nigel O’neill
    December 2, 2011 at 10:36 pm
    [chrisabel noyes] “Apart from the WMV, with were originally MKV files that i converted to WMV (but again, i’ve been working with these files for sometime and had no problem) “
    WMV’s are a terrible format to edit in. I would avoid using WMV files and stick to AVI’s.
    I suspect that the MKV to WMV/AVI conversion process may not conform strictly to the WMV/AVI specifications, hence your issues. I presume this is a 3rd party tool. Has it been updated recently? If so, the developer may have altered the conversion algorithm, which is why problems may be surfacing now, but not earlier.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Chrisabel Noyes
    December 2, 2011 at 11:52 pm
    I use AVS video converter. Would you recommend that from now on i convert the MKV files into AVI?
  • Steve Rhoden
    December 3, 2011 at 2:14 am
    Things may even get better when you do install Vegas 9.0e
    The update fixes several issues that were in the version
    you now have.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Nigel O’neill
    December 3, 2011 at 11:49 pm
    [chrisabel noyes] “I use AVS video converter. Would you recommend that from now on i convert the MKV files into AVI?”
    Chrisabel, the point I am trying to make is you don’t know what AVS Video converter is doing to end up with the AVI/WMV file, and whether it is adhering strictly to Microsoft specifications.
    MKV is not supported by any editing program as far as I am aware, probably because MKV has an open specification and is a playback/player only supported format. The players are open source.
Page 2 of 2
