Activity Forums VEGAS Pro Sony Vegas Movie Studio 12 – how to export closed captions for You Tube
  • Sony Vegas Movie Studio 12 – how to export closed captions for You Tube
    Posted by Maria Maronska on December 17, 2012 at 5:46 pm
    The Sony Vegas Movie Studio 12 help file says that you can insert captions to the timeline by placing the playhead to the specific time and using Insert->Command and then choose TEXT and type in the caption.
    Is there any possibility to export the text commands inserted as described above in a text format, e.g. csv or xml or whatever, that would allow to transform them (possibly using a programming script like VB etc) into the format used by You Tube? Maybe there is a plugin or macro to make it possible?
    Here is a specification how a You Tube caption file should look like:
    https://support.google.com/youtube/bin/static.py?hl=en&topic=2734694&guide=2734661&page=guide.cs
    Matt Crowley replied 13 years, 8 months ago 3 Members · 2 Replies
  • Aleksey Tarasov
    December 17, 2012 at 7:16 pm
    Sony Vegas Pro supports scripting, so you can use scripts to export TEXT commands to subtitles. Afaik, Movie Studio can not do that.
  • Matt Crowley
    December 17, 2012 at 9:21 pm
    Movie Studio’s captions can only be rendered to (embedded in) WMV files. I don’t know if youtube can use captions like this though.
    As Aleksey says, there’s no scripting to export captions from Movie Studio.
