Activity Forums VEGAS Pro Sony Vegas Move Studio HD 10 on 64bit OS
  • Sony Vegas Move Studio HD 10 on 64bit OS
    Posted by Edgar Trejo on May 14, 2011 at 2:39 pm
    Hello,
    I’m new poster to the forums however I’ve been following some of the threads. I want to thank the entire community for all the great work that is done! I have really learned a lot by just reading threads.
    My question:
    I am currently running Movie Studio HD 10 on Windows 7 Home Premium 64bit and vegas is dreadfully slow! I mean, the computer will “think” alot and the windows will constantly dim indicating that it has frozen. The computer I’m running vegas on is:
    Dell XPS
    Core i7-2630qm @ 2GHz
    6gb RAM
    Nvidia GeForce GT 540m + Intel HD Graphics
    64 bit Win7 H.P.
    I don’t think my laptop is the issue… I have also run the program on a Latitude with a first generation i7 with 3gb of ram and only intel hd graphics and it ran without any issue.
    The file I’m working with is:
    extension: .wmv
    length: 15 minutes
    size: 1920 x 1080
    data rate: 781kbps
    total bitrate: 909kbps
    frame rate: 30 frames/sec
    audio:
    128kbps
    channels: 2 (stereo)
    sample rate: 44kHz
    The only thing I could think of is that maybe the file is too big for it’s length and it should be compressed?? But I don’t know much about it and don’t know if that could be the issue. Any help would be greatly appreciated!
    John Rofrano replied 15 years, 3 months ago 3 Members · 4 Replies
  • Stewart Bourke
    May 14, 2011 at 3:59 pm
    Vega Movie Studio is not 64 bits, so even if running it on a 64 bit machine with all that RAM it will still only us the 2Gb…
    I used to be given .wmv files to edit on movie studio, and even files of 2-3Gbs caused issues. Vegas does not like wmv files as it is quite compressed, and previewing is always choppy (it was for me in any case..) I would trying out converting the file into something something like mpeg2 if you are on SD. I don’t work in HD (yet) so I cannot suggest what format to use for HD – as you seem to be working in a HD format – but transcoding them into a less compressed format should give you a better previewing experience…
  • John Rofrano
    May 14, 2011 at 5:28 pm
    [Edgar Trejo] “Core i7-2630qm @ 2GHz”
    This is below the specs of 2.8Ghz recommended by Sony. You only have 2/3 the CPU power you need. Also, 2.0Ghz on a laptop is not the same as 2.0GHz on a desktop. Laptop processors cannot be measured by clock speed alone.
    I also agree with Stewart that editing WMV is not a good idea. Normally, I would recommend that you convert them to CineForm, but that’s a $99 purchase and I realize that’s almost the cost of Vegas Movie Studio itself.
    Alternately, you could convert them to AVI Motion-JPEG video and PCM audio with a tool like AviDemux. This format should edit smoothly in Movie Studio. You could also just render them to HDV 1080-60i files from within Movie Studio.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Edgar Trejo
    May 14, 2011 at 5:45 pm
    I made a bad choice then! Because the original video file was a .mp4 file from some JVC camcorder but Vegas couldn’t read it correctly for some reason. I would import and play but both the video and the audio were very jumpy. I read on other forums that this was due to an mp4 issue vegas has with quicktime. I did the fix and even uninstalled all apple software but it didn’t work. So, i found it much easier to convert to another format and .wmv seemed to import very smoothly with the best picture quality.
    I’ll go ahead and try converting the mp4s to avi.
    Another quick question:
    In PROJECT – RENDER AS- I have the option to save in various file types but below that I also have a section called “template” which lets me choose from NTSC DV and PAL DV among others. The “others” are HD 1080-60i with a variation of 50i and 24p. What is the difference?
    Thanks for everything so far!
  • John Rofrano
    May 14, 2011 at 9:18 pm
    [Edgar Trejo] “I made a bad choice then! Because the original video file was a .mp4 file from some JVC camcorder but Vegas couldn’t read it correctly for some reason.”
    Yea, you went from one highly compressed lossy format to another highly compressed lossy format and as you saw, that got you nowhere. The correct thing to do is to buy CineForm and use that as your digital intermediary format.
    [Edgar Trejo] “Another quick question:
    In PROJECT – RENDER AS- I have the option to save in various file types but below that I also have a section called “template” which lets me choose from NTSC DV and PAL DV among others. The “others” are HD 1080-60i with a variation of 50i and 24p. What is the difference? “
    The file format known as AVI is just a container. It can contain video and audio that are compressed with any number of codecs. The templates let you select the codec to use to encode the video. The NTSC DV and PAL DV templates with use the DV codec. The HD templates will use the Sony YUV codec. Depending on how you want to deliver your final video will determine what file format and codecs you should use.
    ~jr
