Activity Forums VEGAS Pro Sony Vegas is on its way back.
  • Sony Vegas is on its way back.
    Posted by Steve Rhoden on September 26, 2012 at 10:28 pm
    Installed Vegas 12 on an old averagely built 64bit system,
    with basic GPU processing, And man i tell you, there isnt a glitch,
    no crashing or hiccups no matter what i do.
    It Ingest every format i through at it flawlessly, including
    Panasonic P2 format (no more need for Raylight).
    Obviously there’s got to be a few bugs lurking in there, but
    havent come across any as yet, but we still have a long way
    to run it through its paces first….. But so far Vegas 12
    is looking great….whewwww
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
    Matt Carlson replied 13 years, 11 months ago 6 Members · 9 Replies
  • 9 Replies
  • Guillaume Jeffrey
    September 27, 2012 at 3:08 am
    You are lucky… For me 12 is as unstable as 11…
  • Steve Rhoden
    September 27, 2012 at 8:19 am
    Are you running it on the same system you have Vegas 11
    installed on Guillaume?
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Al Bergstein
    September 27, 2012 at 1:10 pm
    Great to hear that Steve. I’ll load it up after my latest batch of time sensitive projects are done.
    Al
  • Guillaume Jeffrey
    September 28, 2012 at 12:58 am
    Yes Steve, I run both version on the same computer. The last built of VP11 (701) is a lot more stable though.
    Guillaume
  • Steve Rhoden
    September 28, 2012 at 1:36 am
    Dont.….
    Run Vegas 12 alone on a system, with no other
    versions of Vegas installed. The errors of Vegas 11 will port
    over to Vegas 12 it seems.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Guillaume Jeffrey
    September 28, 2012 at 3:49 am
    [Steve Rhoden] “Dont…..
    over to Vegas 12 it seems.”
    Steve,
    Where did you get this information from?
    Guillaume
  • Nigel O’neill
    September 30, 2012 at 11:33 am
    [Steve Rhoden] “The errors of Vegas 11 will port over to Vegas 12 it seems.”
    If that is true, that sucks big time for me. It effectively means wiping my main editing system and rebuilding from scratch or starting with a vanilla system. No thanks!
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 11 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Dave Haynie
    October 4, 2012 at 9:33 pm
    [Steve Rhoden] ” The errors of Vegas 11 will port
    That should not be true. At least since Vegas Pro Audio, installs have been completely independent of one another.
    -Dave
  • Matt Carlson
    October 7, 2012 at 2:13 am
    The registry entries for all common/shared and third party plugins are used collectively between 11 and 12 (and probably have been since 9 up.) Also I noticed something that I did not expect. I registered 12 with my full name while 11 was registered under a company. Vegas 11 is now registered under my name as well… so that means not just plugin registry info is being shared but other basic info as well. The idea that certain OFX crash symptoms are ported to 12 or other possibilities of environment badness being shifted through shared plugins is not a stretch.
