Sony Vegas Error… Ur.gent! He,Lp!
Posted by Colin Wuzhere on June 9, 2015 at 5:13 amSo I was recording CrazyBob’s CnR, (GTA San Andreas Online Server..)
And I put the clip into sony vegas and this happens…
https://www.youtube.com/watch?v=jABqKuhY95g&feature=youtu.be
Jorge Talamantes replied 11 years, 2 months ago 2 Members · 4 Replies -
Jorge Talamantes
June 9, 2015 at 6:06 amthe problem is that you are missing some keyframes on the video check you framerate on your screen recorder program or also the bitrate, one of those to values may be to high, you can also try updating your codecs i use klite mega codec pack and works very well
Colin Wuzhere
June 9, 2015 at 6:33 amOH also, I use Dxtory. I record with 100 FPS. And it runs so smoothly and beautiful. I put it into Sony Vegas Pro 13, and that happens…. I will try your codec.
Jorge Talamantes
June 10, 2015 at 6:26 amthis is the link to the video
https://www.youtube.com/watch?v=qbGQBT2Vwvc
you could try recording at 60 FPS wich is a more common framerate
https://www.codecguide.com/download_k-lite_codec_pack_mega.htm
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
