Sony Vegas crasheswhen i try to open or import an H.264 video
Posted by Blahtor Magnus on August 15, 2008 at 5:37 pmMy Sony Vegas crashes when I try to open or import an H.264 video (MOV files, taken directly from my Aiptek A-HD+ camcorder).
Any idea how to fix that?Thanks!
John Frey replied 17 years, 9 months ago 3 Members · 4 Replies -
John Rofrano
August 16, 2008 at 3:13 amThis is a known problem with the Aiptek HD camcorders. You need to transcode them to another format before you can use them in Vegas. Just follows Keith Kolbo’s excellent tutorial: Using GO-HD files in Sony Vegas Pro 8. You will need to purchase Quicktime Pro ($29USD) or find some other way to transcode them.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Blahtor Magnus
August 16, 2008 at 11:26 amThanks.
I was wondering if there is a way to use the files directly in Vegas, without having to convert them first.I just got back from the seaside and there are like 140 vacation videos stored on my SD card.
I would like to edit them and make a documentary but it would be a nightmare to convert the videos one by one, even with the fastest converter.
It looks like QuickTime can’t do lossless batch converting. Or could it? -
John Rofrano
August 16, 2008 at 12:22 pmThere is no way to use these directly in Vegas. It looks like Quicktime processing is lossless. It’s just doing a stream copy to rewrite the file in the correct format. Unfortunately there is no batch processing.
Needless to say, anyone who buys a new camera should check that it works with their computer software before buying it. It looks like this camera works fine on a Mac but has problems with a PC.
~jr
John Frey
August 19, 2008 at 3:11 amIf you have a later version of Nero, import them into Nero Vision, their rudimentary NLE, via Make Movie. Then you can export them to Cinema AVC which is 1280 x 720, or, either Nero Digital or Nero Digital AVC at 1920 x 1080. They will look and play fine in Vegas 8. The Nero Showtime player does a good job with all of these files.
John D. Frey
25 Year owner/operator of two California-based production studios.Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
