Activity Forums VEGAS Pro Sony vegas crash when doing any thing.
  • Sony vegas crash when doing any thing.
    Posted by Kashif Etternavn on August 22, 2010 at 7:19 pm
    Hi, sony vegas suddently started to crash every time i imported media or try to open a project.
    I get a”vegas pro has stopped working” meassage and if i want to send an error report.
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0c (Build 896)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: D:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
    Norman Willis replied 16 years ago 2 Members · 4 Replies
  • Norman Willis
    August 23, 2010 at 2:34 am
    Try the easy stuff first. Run a scandisk (and a defrag), and then upgrade to 9.0e. (It is free.)
    Also, if that does not work, have you made any hardware or software changes recently? If so, can you roll your system back?
    Let us know how you do.
    Norman Willis
    http://www.nazareneisrael.org
  • Kashif Etternavn
    August 23, 2010 at 1:53 pm
    None of the suggestions worked 🙁
    when the problem began it came at the splash screen but that solved it self after a couple of hours. Now it crashes every time i try to load media, projects any thing!
    the problem started after i installed roller coaster tycoon 3 :p
  • Kashif Etternavn
    August 24, 2010 at 8:28 pm
    Any solution?
  • Norman Willis
    August 24, 2010 at 9:31 pm
    Uninstall roller coaster tycoon.
    Norman Willis
