Activity Forums VEGAS Pro Sony Vegas capture 16.9 to 16.9 ex handycam
  • Sony Vegas capture 16.9 to 16.9 ex handycam
    Posted by Ben Smart on April 16, 2008 at 11:52 am
    I have a Sony Handycam HC96E which I’am to believe records in true 16.9 my problem is whenever i capture it using Sony Vegas Pro 8 it doesn’t seem to to capture in 16.9 although when i was using Picture Package that came with the camera it does I have been searching the net for days trying to nut this out but to no avail any help would be much appreciated or a link to a tutorial because i just can’t figure it out.
    Thank you
    Leslie Wand replied 18 years, 4 months ago 2 Members · 3 Replies
  • Leslie Wand
    April 17, 2008 at 10:20 am
    make sure your project matches your captured footage:
    file > properties > little folder in right corner > point to captured footage.
    leslie
  • Ben Smart
    April 17, 2008 at 3:16 pm
    Thanks leslie
    I seemed to have worked through that. Just wondering will I have to select captured footage (via properties & folder in the right corner) everytime and is that the true 16.9 ex handycam when I select the footage or is it stretched if so is their a way to mirror the 16.9 ex handycam during capture as to avoid streching.
    Ben
  • Leslie Wand
    April 17, 2008 at 11:08 pm
    don’t know the camera.
    as for every time – you can set it as a default – click button, and it’ll always start a new project with the cameras settings….
    leslie
