Activity Forums VEGAS Pro Sony vegas cant install AppData – Local Temp. ?
  • Sony vegas cant install AppData – Local Temp. ?
    Posted by Mikkel Nielsen on July 31, 2009 at 12:18 pm
    Hello there, i recently downloaded the 30 day trial from the sony vegas (9.0 PRO) webside, and got the installer down, when i run it it says something like unable to write to the temp directory in C:/Users/Username(in this case Mikkel)/AppData/Local/temp/. Check that you have write acces to this directory – Ive tryed to run as adminstrator – doesnt help, the AppData is neither protected by something that wouldnt allow sony to do whatever it wants to or anything – anything that might help me out of this would be lovely! thank you!
    Jeremy Rasnic replied 17 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Rasnic
    July 31, 2009 at 8:53 pm
    Delete your temporary files and if that doesn’t work, just to be on the safe side, you may want to re download Sony Vegas again to make sure you don’t have a corrupt install.
    Let us know if that fixes it.
    j razz
    https://www.jrazzcreations.com
