Activity › Forums › VEGAS Pro › Sony Vegas 9.0 Platinum “Exception has occured” Error
  • Sony Vegas 9.0 Platinum “Exception has occured” Error
    Posted by James Wagner on November 11, 2011 at 8:00 pm
    Just currently finished up a 14 minute long edit, but every time I try and render the project (either in .wmv or .mov formats), I receive an error message that says “An error occured while creating the media file [filename].wmv The System is low on memory”
    Other times I get one that says “An error has occured while creating the media file [filename].wmv An exception has occured”
    Here are the details for that particular message:
    Vegas Movie Studio Platinum 9.0
    Version 9.0 (Build 55)
    Exception 0xC0000005 (access violation) READ:0x7CA0003C IP:0x6C169519
    In Module ‘QuickTimeAuthoring.qtx’ at Address 0x6C030000 + 0x139519
    Thread: ProgMan ID=0x15F0 Stack=0x668F000-0x6690000
    Registers:
    EAX=7ca0003c CS=0023 EIP=6c169519 EFLGS=00010207
    EBX=00000000 SS=002b ESP=0668f0dc EBP=0668f180
    ECX=7ca0003c DS=002b ESI=6a5bbc68 FS=0053
    EDX=059d4b44 ES=002b EDI=00000000 GS=002b
    Bytes at CS:EIP:
    6C169519: 2B 08 89 4C 24 04 E9 48 +..L: 91 EC FF 90 90 90 90 90 ……..
    Stack Dump:
    0668F0DC: 6C169183 6C030000 + 139183 (QuickTimeAuthoring.qtx)
    0668F0E0: 7CA00040
    0668F0E4: 00000000
    0668F0E8: 04EB1730 04DF0000 + C1730
    0668F0EC: 00000000
    0668F0F0: 6C1676FC 6C030000 + 1376FC (QuickTimeAuthoring.qtx)
    0668F0F4: 0668F190 06590000 + FF190
    0668F0F8: 80008002
    0668F0FC: 6AF81255 6AF00000 + 81255 (QuickTime.qts)
    0668F100: 00000000
    0668F104: 00830008 00400000 + 430008 (VegasMovieStudioPE90.exe)
    0668F108: 6C16746F 6C030000 + 13746F (QuickTimeAuthoring.qtx)
    0668F10C: 04EB1730 04DF0000 + C1730
    0668F110: 0668F190 06590000 + FF190
    0668F114: 6C167670 6C030000 + 137670 (QuickTimeAuthoring.qtx)
    0668F118: 00830008 00400000 + 430008 (VegasMovieStudioPE90.exe)
    > 0668F120: 6AF811A1 6AF00000 + 811A1 (QuickTime.qts)
    > 0668F134: 6AF81E96 6AF00000 + 81E96 (QuickTime.qts)
    > 0668F138: 00830008 00400000 + 430008 (VegasMovieStudioPE90.exe)
    0668F13C: 0668F190 06590000 + FF190
    0668F140: 113ABAF8
    0668F144: 0668F1BC 06590000 + FF1BC
    0668F148: 04EBD680 04DF0000 + CD680
    > 0668F15C: 6AF81150 6AF00000 + 81150 (QuickTime.qts)
    > 0668F174: 6AF56620 6AF00000 + 56620 (QuickTime.qts)
    > 0668F184: 6AF6BD9E 6AF00000 + 6BD9E (QuickTime.qts)
    > 0668F188: 00830008 00400000 + 430008 (VegasMovieStudioPE90.exe)
    0668F18C: 0668F190 06590000 + FF190
    0668F190: FFFE0400
    > 0668F194: 00830008 00400000 + 430008 (VegasMovieStudioPE90.exe)
    > 0668F198: 6AF7F8D9 6AF00000 + 7F8D9 (QuickTime.qts)
    > 0668F19C: 00830008 00400000 + 430008 (VegasMovieStudioPE90.exe)
    0668FFF0: 00000000
    0668FFF4: 00527F10 00400000 + 127F10 (VegasMovieStudioPE90.exe)
    0668FFF8: 00AEFB48 00400000 + 6EFB48 (VegasMovieStudioPE90.exe)
    0668FFFC: 00000000
    I’m desperate for help here. I’ve been working on this project for weeks, and the deadline is fast approaching.
    Barry De passey replied 14 years, 10 months ago 3 Members · 3 Replies
  • Steve Rhoden
    November 11, 2011 at 8:18 pm
    Render it out as NTSC-DV and see if all renders well.
    If it does, you simply drop the new render back on the
    timeline and render out to whatever format you want.
    Always difficult to know what really gives those errors
    and failures.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • James Wagner
    November 11, 2011 at 10:15 pm
    Thanks for the response. I’m trying to render it as NTSC-DV now, but it’s stopped rendering at the 64% mark for the past 10 minutes or so, with the estimated time remaining sitting on 00:00:00. Should I just leave it alone for a while or cancel it and start over?
  • Barry De passey
    November 13, 2011 at 10:41 am
    I was having the “low on memory” error sporadically when trying to render my videos. The only way I could fix it was to open Sony Vegas again (so two running at the same time) and copy and paste my timeline pieces to the new Vegas and new timeline. Quick and easy to do and was the only fix for me. Hope it is some help.
