Activity Forums VEGAS Pro sony vegas 9 timeline problem
  • Elliot Perkins
    September 8, 2009 at 6:57 am
    I have taken a screenshot of what is happening
    1. The video is playing
    2. I press “s” to make a cut
    3. It cuts where the “black” circle is not at the “white” circle which is the the current time.
    its like after I make the first cut, the “where you were line” becomes the active line from then on, and any further cuts happen at the “where you were line” from then on.
  • Mike Kujbida
    September 8, 2009 at 10:42 am
    Have you tried re-installing Vegas yet?
  • Elliot Perkins
    September 8, 2009 at 8:53 pm
    yes i have reinstalled and updated to 9b and im still getting the same problem.
  • Mike Kujbida
    September 8, 2009 at 10:32 pm
    All I can say is that there’s something very strange going on with your system as no one who’s replied so far can reproduce your problem.
    I just tried it again doing everything you’re having troubles with and had no problems making a split where I wanted.
  • Elliot Perkins
    September 8, 2009 at 11:03 pm
    so theres no reason why the “where you were line” would ever become the place where cuts happen only the “where you are line” or current time
    1 vegas cuts correctly on the very first cut.
    2 then when i go to delete a section
    3. then play again and press “s” to cut, it cuts at the “where you were line” not at the current time.
  • Roger Crunden
    October 29, 2011 at 2:04 pm
    Has anyone got to the solution to this issue? I would have expected it to be just a question of a setting? The issue I’m having on pro 9 appears to be very similar to previous posts above – when I’ve paused on the time line and then restart a black line is left where I had paused. When I stop further along the timeline the cursor goes back to my previous pause position. How can I stop the cursor going back. I’m unable to acurately trim and adjust the clips the way things are.
    Roger
  • David Holguín
    March 29, 2017 at 6:37 pm
    https://postimg.cc/image/dnrtz4ai7/ Check this picture out. I guess I had the same “issue”. One has to click on the timeline part indicated by the upper arrow to edit normally. If ones click on the actual timeline, say on the video, it happens what you commented on your post.
Page 2 of 2
