Activity › Forums › VEGAS Pro › Sony Vegas 8.1 won’t render. error message comes up
  • Sony Vegas 8.1 won’t render. error message comes up
    Posted by Amber Rivera on February 1, 2011 at 10:40 pm
    Hi, I have Vegsa 8.1, and when I try rendering a project, it errors out and says that there isn’t enough memory. To close other programs and try again. Can anyone help?
    I am running Windows 7 64bit and 8.1 is supposed to be compatible
    – Amber Rivera
    John Rofrano replied 15 years, 8 months ago 2 Members · 3 Replies
  • John Rofrano
    February 2, 2011 at 1:48 am
    [Amber Rivera] “I am running Windows 7 64bit and 8.1 is supposed to be compatible”
    Actually no. Vegas Pro 8.1 came out before Windows 7 and is only “officially” compatible with Vista. It also has it’s share of bugs. I personally, wouldn’t use it for production work. It’s more of a “technology preview”. You should upgrade to Vegas Pro 10 if you want to run in Windows 7 64-bit. If not, try using Vegas Pro 8.0c which is newer than 8.1.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Amber Rivera
    February 2, 2011 at 6:33 am
    Ohhh ok wonderful, I’ll definitely try 8.0c. Do you know if I’ll have to reinstall the newblue fx again? Because when I went from 8.0a to 8.1, the newblue fx weren’t compatible with the ones I had used in my project so I had to do them all over again
  • John Rofrano
    February 2, 2011 at 12:38 pm
    Yea, 8.0c is 32-bit and 8.1 it 64-bit so they require different plug-ins. I don’t know if NewBlueFX installs both versions by default but if they don’t you’ll have to install the 32-bit versions.
    ~jr
