Activity Forums VEGAS Pro Sony Vegas 8 m2t Capture Issues
  • Sony Vegas 8 m2t Capture Issues
    Posted by Mark Caesar on July 15, 2008 at 11:53 pm
    I have 2 different computers: Thinkpad z60m running Vista and a Sony VAIO Desktop Dual-Processor running XP. I just updated the VAIO to SP3 yesterday as the computer has been in storage for several months.
    I installed Vegas 8.0a on the VAIO so I could use it exclusively for video editing with my Sony HVR-Z1U HD Camera. I have been using this combination for several years.
    When I went to capture from the camera, it did the usual business: ripped all of the multiple clips to individual m2t files on my secondary drive.
    However, after finishing, Vegas on the VAIO cannot recognize the m2t files. It gives the “unsupported format” error message. I’ve searched for several hours on the forums and tried all of the solutions posted and have had no luck.
    Even more strange is that when I copy a file ripped from the VAIO over to the Thinkpad, I can import no problem! Same version number, same serial, everything….
    Bananas
    Shafiq Khokhar replied 17 years, 4 months ago 5 Members · 5 Replies
  • Jeremy Rasnic
    July 16, 2008 at 1:24 pm
    Are you able to uninstall sp3? It sounds like one of your codecs got messed up (and from what you wrote, the only change you made was sp3).
    That would be option number one for me if I were in your shoes. What is below may or may not prove any difference.
    If you want, you can try this: https://www.sonycreativesoftware.com/forums/ShowMessage.asp?MessageID=602126&Replies=143
    There is no warranty or guarantee concerning this. It is something that the Sony engineers are looking to implement in version 8.0c. It may or may not help you and it involves replacing a dll file. Make sure you do a system restore before trying this.
    If you would like to help test the pre-release HDV reader for Vegas Pro 8, please follow these exact steps:
    1) Download the file “M2tsplug.zip” from this ftp site:
    {you must go to the thread provided in the link above and look for the second post from the forum adminstrator. Then please follow the instructions below.}
    2) unzip
    3) copy the file
    m2tsplug.dll
    into (default path) C:\Program Files\Sony\Vegas Pro 8.0\FileIO Plug-Ins\m2tsplug .
    Choose yes when prompted to over-write.
    4) Restart Vegas> Load up any HDV files or HDV projects you have been having trouble with.
    5) Please post your results back to this thread. Don’t start another thread.
    6) If you run into problems, please post details. Critical details are
    a) full system specs
    b) problem file genealogy
    – What device recorded this file?
    – Was the tape brand new, or was it used once or more?
    – What application was used for capture?
    – Has this file been opened or saved in ANY other application, such as Womble, or Premiere.
    – What problem did you encounter (stability, red frames, black frames, other)
    The more detail the better.
    Please limit your comments in this thread to HDV file problems only. This beta HDV reader does not change the behavior of other source file types, it is for checking HDV .m2t files only.
    If you run into a problem with this new reader, please delete this file (m2tsplug.dll) and un-install/ re-install Vegas Pro 8.0b.
    Do not contact SCS tech support about this pre-release HDV reader for Vegas Pro 8. This needs to be thought of as a component beta test between you, and SCS engineering.
    Good luck, and we look forward to your results.
    SCS dev
    j razz
  • Mark Caesar
    July 16, 2008 at 3:19 pm
    I seem to have found a solution for now. I installed “Sony Media Manager” first before installing Vegas. Everything is working so far. I did not need to install it on the other computer but I’m done trying to figure this thing out.
    Media Manager is memory intensive but at least I can drop my m2t files into the timeline. I will post again tosee if any other problems come up…
  • John Frey
    July 16, 2008 at 8:10 pm
    I know of others having problems after updating to SP3.
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
  • José Matute
    August 20, 2008 at 6:29 pm
    Hi. Im having some issues with vegas, I used to work with Premier so I got used to the whole Avi. scene. I have no problems with .m2t but I recently rented my HD1000 to some college students and they want the footage in .avi Im not sure where im supposed to convert them from AVI using Vegas.
    Oh and another thing, Premier wont capture HD from my HD1000 camera.
    Any tip would be greatly appreciated. Thanks!
  • Shafiq Khokhar
    April 16, 2009 at 6:12 pm
    Im trying to capture .m2t on a 64bit vista system but it eventually stops capturing on its own while the capture device is still running?
    can someone please fill me in?
