Activity Forums VEGAS Pro Sony Vegas 8: Can’t import MP4 file, get error message
  • Sony Vegas 8: Can’t import MP4 file, get error message
    Posted by Julie Cohen on January 5, 2012 at 5:03 pm
    I have a 3.32GB MP4 file that I want to edit in Sony Vegas. When I try to put the file into Vegas I get the following error message: An error occurred while opening one or more files. The reason could not be determined. The file couldn’t be opened.”
    I tried playing the files in my (updated) QuickTime player and they work fine. Any suggestions would be greatly appreciated.
    Mike Kujbida replied 14 years, 8 months ago 3 Members · 4 Replies
  • Mike Kujbida
    January 5, 2012 at 7:10 pm
    No matter what version of QuickTime you’re using, Pro 8 is too old to be able to recognize newer mp4 files.
  • Doyal Gudgel
    January 6, 2012 at 7:13 pm
    I have a similar question. I have an old cd with apparently WAV files. I imported some with Vegas 9 but it would not open one I tried but it said it was not a supported file. How come? I opened a .vf file with vegas nine then looked at the way it could render the file. In that list was WAV. So if it can render it as a WAV how come it says it is not a supported file? Doesn’t make sense to me. But I am sure there is an explanation I don’t know about. In the meantime I would suggest Julie do what I did and open a project then look at the ways it will render it.
    Have a nice day.
  • Doyal Gudgel
    January 6, 2012 at 7:23 pm
    Change “save” to “render” as Sorry (whew! Mike)
  • Mike Kujbida
    January 7, 2012 at 2:09 pm
    “I have an old cd with apparently WAV files. I imported some with Vegas 9 but it would not open one I tried but it said it was not a supported file.”
    The files on a CD show up as something other than WAV files if you look at them through Windows Explorer.
    Try the “Extract Audio From CD” option.
