Activity › Forums › VEGAS Pro › Sony vegas 7 won’t render with Windows 7 64bit
  • Sony vegas 7 won’t render with Windows 7 64bit
    Posted by Amber Rivera on January 10, 2011 at 5:14 am
    So I’ve always used sony vegas 7. I installed windows 64 bit on my HP laptop with 4 gb of RAM, as well as installing vegas. Everythings fine, I can add clips, effects, etc, but once I hightlight stuff to render, it just crashes and says error (and gives me a huge error code) or just crashes. I’ve uninstalled and re-installed and it doesn’t work. I’ve even taken it to Geek Squad at Best Buy and they weren’t sure either. They suggested installing the newest version of vegas, so I did. Vegas 10. Buuuut, now the serial for vegas 10 won’t work or install 🙁
    Hope someone can help!
    Steve Rhoden replied 15 years, 8 months ago 2 Members · 1 Reply
  • Steve Rhoden
    January 10, 2011 at 7:07 am
    That’s right, Vegas 7 is not a fully compatible version for
    Windows 7, That is why you are having the issues.
    A newer version is what you need for windows 7 and using your
    Vegas 7 serial will not work for Vegas 10, its not an update,
    its a new version all together you have to purchase.
    If you intend to continue using Vegas 7, then Windows XP is
    what it needs to be running on.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
