Activity Forums VEGAS Pro sony vegas 6 problem
  • sony vegas 6 problem
    Posted by Wesley O. on June 27, 2006 at 11:52 pm
    I’M WORKING ON A VERY LARGE PROJECT WITH VEGAS 6 (96 MIN) WITH LOTS OF TRACKS. THE PROJECT IS ALMOST COMPLETE. SUDDENLY THE PROJECT FILE WON’T OPEN. BACKUPS OF THE FILE OPEN WITH AN EARLIER VERSION OF THE PROJECT THAT IS ALMOST EIGHT WEEKS OLD. MY BACK UP EXTERNAL HARD DRIVE HAS THE SAME EXACT PROBLEMS.
    THE PROJECT DID OPEN ONCE BRIEFLY AND CLOSED UP. SO I KNOW THE PROJECT FILE IS STILL THERE AND INTACT.
    HAS ANYONE ELSE HAD THIS PROBLEM? WERE YOU ABLE TO FIX IT? AND HOW DID YOU FIX IT?
    ANY HELP WITH THIS PROBLEM WILL BE GREATLY APPRECIATED. THANK YOU.
    SINCERELY WES
    Mike Kujbida replied 20 years, 2 months ago 3 Members · 2 Replies
  • Gary Kleiner
    June 28, 2006 at 12:20 am
    Wes,
    First, do not type in ALL CAPS. That is bad manners.
    Vegas makes automatic project backups with a .bak extension. Find the latest one and give it a new name with a .veg extension and see if it opens.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Mike Kujbida
    June 28, 2006 at 2:06 am
    To add to Gary’s suggestion, here’s Sony’s answer:
    Question:
    My project file will not open, what can I do?
    Answer:
    Go into your Start menu and select Search or Find and Files and Folders. Then search for *.bak in this window. Look for a project file labeled with the same name with .bak after it and try to open it. If the project opens, go into the File menu and select Save As. Then save the project under a new name in a different location and continue on with that project.
    If the program that you are using supports VST plug-ins, you may be able to narrow it down to a VST problem. To do so, try renaming C:\Program Files\Vstplugins to “Vstpluginsx” for example, and trying to start the program again. If it launches fine, it is a problem with one of your VST effects/instruments. At that point you may have to uninstall and reinstall your VST plug-ins or update the plug-ins from the manufacturer’s website. You may also want to try using VST-Scanner to search for a broken VST plug-in.
    Uninstall the program, using the Add/Remove Programs utility in the control panel. Then go into the Program Files folder in the C drive and into the Sony and Sony Set-up folders there and delete the folders labeled with that program’s name. After doing so, re-install the update only if there is one available for your program, it will be located here. If there is not an update available there, then just install the program with the CD or install file that you originally installed the application with.
    Rename the folder that the media is in for this project and then try opening the project file. Once you have the “missing media” dialog open, do not allow the program to automatically find any of the media clips from that project. Select to find the clips manually. This should allow you to locate the specific clip that causes the problem.
    If the program has Media Manager included, you may want to try disabling Media Manager. To do so, first save your project and go into the Options menu and select Preferences. Then towards the bottom of the General tab, uncheck the box next to “Enable Media Manager” and press Apply and OK. Then close the program and re-open it.
