Activity › Forums › VEGAS Pro › Sony Vegas 50 mbps output for broadcast?
  • Sony Vegas 50 mbps output for broadcast?
    Posted by Dan Hart on September 23, 2011 at 7:10 am
    Ive been asked to provide a broadcaster with a file that Im finding impossible to create with Vegas, Im not a file genius but have what I thought was a reasonable knowledge – but Im well and truly stuck with this….
    The file needs to be Mpeg 2, 720 x 576, 4:2:2, I frame only, 50mbps. The thing Im having the biggest problem with is the bit rate – In the custom setting, I set the bit rate at 50mbps but as soon as I press OK it reverts to 18.5 mbps. The broadcaster will also accept the file as 1920 x 1080 but in this case the bit rate would need to be 100mbps – I have managed to get it to 25…
    Im running Vegas 10e 64 bit on windows 7 64 bit if that helps. Any help with this would be greatly received.
    Cheers,
    Dan
    Roger Bansemer replied 15 years ago 3 Members · 3 Replies
  • Roger Bansemer
    September 23, 2011 at 2:05 pm
    I produce a TV series for PBS and I use the:
    Sony MXF format to give to CaptionMax who take it from there to make an HDCam master tape.
    Here are the settings in Vegas I use to produce the file.
    custom settings on the Sony MXF video tab are:
    Video format – HD
    1920×1080
    16:9
    Upper field first
    Video quality – high
    profile 422
    Hope that helps.
  • Jonathan Thomas
    September 26, 2011 at 3:53 pm
    Hi Roger,
    What camera did you use to film the event?
    JT
  • Roger Bansemer
    September 26, 2011 at 4:20 pm
    I use several cameras. Primarily a Sony Z1U.
    But I use other much less expensive cameras as well such as the Sony XR520. I edit on a 42 inch monitor and I can’t tell any difference in quality despite what some might say.
