[Garret Robinette] “But in the Preview nothing is messed up, even in pan and crop.”
Usually when you set the Preview to Best (Full) it will show you exactly what will be rendered. If that shows the problem, then start disabling FX and crops, etc. to see what might be causing it.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
